  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Paul i probably wont sleep all night ...... so yes nanna nap ..... this is coming from a guy that takes one quite frequently!
eh? since when have i chained you up and spanked you?
Niz, I just read something on the net, sounds like a good idea for an SAU party:D
GERMANS are screaming, moaning, and panting for the latest nightlife craze: porno karaoke.
Film producers Satt und Durstig organised a premiere in Berlin last month after a successful test run in the northern city of Hamburg, and the trend has already spawned imitators in other major cities.
Porno karaoke is similar to traditional karaoke - but, instead of standing in for Whitney Houston or Frank Sinatra, contestants belt out the soundtracks of adult movie stars.
Players pair off in male-female teams as an XXX film is loaded into the projector. With the sound turned off, each duo is handed two microphones, and has one minute to provide the aural fireworks for the action on the screen.
The crowd, which tends to find the show more comic than erotic, then chooses the couple that has given the most convincing, creative, and ecstatic performance of faking an orgasm before hundreds of strangers.
Paul dad pointed to the indicator (which is smashed) and goes "So you ordered a new indicator yet mate?" and he goes" oooh does it need one does it?" *bashes head on wall* apparently dad was pissed off and got pretty angry at them :wave:
haha that sounds funny ..... porno karaoke :cheers:
My mother taught me to read when I was four years old (her first
mistake).
One day, I was in the bathroom and noticed one of the cabinet doors was ajar. I read the box in the cabinet. I then asked my mother why she was keeping 'napkins' (Stayfree pads) in the bathroom. Didn't they belong in the kitchen?
Not wanting to burden me with unnecessary facts, she told me that those were for "special occasions" (her second mistake).
Now fast forward a few months....It's Thanksgiving Day, and my folks are leaving to pick up my uncle and his wife for dinner. Mum had assignments for all of us while they were gone. Mine was to set the table.
When they returned, my uncle came in first and immediately burst into laughter. Next came his wife who gasped, then began giggling. Next came my father, who roared with laughter. Then came Mum, who almost died of embarrassment when she saw each place setting on the table with a "special occasion" napkin at each plate, with the fork carefully arranged on top. I had even tucked the little tail in so they didn't hang off the edge!!
My mother asked me why I used these and, of course, my response sent the other adults into further fits of laughter. "But, Mum, you SAID they were for special occasions!!!"
yeah understood but they shouldnt be promising something they cant deliver and cmon - a smashed indicator is something they shouldve noticed. Plus they are just figuring out how phucked up the front bar is now ..... a month after they've had it! They've just discovered now that they are going to have to send it out to be refibreglassed!!
Nah not about me :cheers: thought that was hella funny tho! I wasnt taught to read at age 4 ...... i think it was the older kids at school that taught me to read ...... i was always the favourite with the older kids when i was little :wave:
    • Yeah, plenty of air flow, there is a dedicated path that feeds the air in to the OEM intake tube behind the bumper As for a "tangible effect", maybe, but getting the pod/intake air out of the hot engine bay is worth it psychologically to me, even if it gives no performance difference, so the tangible effect in my Lizard brain saysss yessss  In the end, to me a tangible effect isn't always about performance, sometimes it a sound or a look, or even a...... feeling  Ooga-Chaka Ooga-Ooga Ooga-Chaka Ooga-Ooga Ooga-Chaka Ooga-Ooga Ooga-Chaka Ooga-Ooga
    • yeah first and reverse is where you will find clutch release issues (whether hydraulic or mechanical) because the difference in revs required is the highest there; particularly changing down from 2nd to 1st when still moving. To be clearer though, it is possible that the clutch release bearing is the wrong height. This is less likely than a hydraulic issue but it is not unheard of when you are mixing and matching
    • Quite right, if you make it to that pension you deserve every cent
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
