yeah well i was trying the mind over matter approach paul but you just shot that idea down ;) haha ..... yeah i know ..... parents huge minus.... lack of freedom minus ...... free rent, free internet, heated pool and spa and pets allowed is a huge plus tho ....... its a lose lose situation stay or go but i think i'll just save and start buying bits n pieces and get myself organised ;)
  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Morning yall. Not a good 1 though.
So im lying in bed last nite and i hear a car alarm go off. I figure since the4 parents have friends around its gonna be one of them drunkenly stuffing up and making theirs go off.
I get up in the morning and hit the immobiliser when the key is in theon position as u usually do. The engine cranks over but it wont fire :confused: i look at the little batt, parkbrake lights etc and they are all off. The imobiliser is clicking on and off indicators flashing but no dice. I keep cranking it like the moron i am then get out, the fuse in the immobiliser is fine. I disconnect the batt and push the brake for a bit which only reset my clock and didnt do much else.
Any ideas cause i hate paying sparkys
i want pillar mount .... you know the one that fits on the pillar in nice casing ...... i dont want this huge dial sticking out in the middle of god knows where ...... one like yours paul.
But also saying that i dont want to spend a ridiculous amount on a phucking gauge!
Damn Boosty!! ;)
Paul no rush - might as well leave it til i get the veilside on and the car is once again fulltime mine!! and no i havent seriously started job hunting yet.
Aidiwn ..... you need intercooler etc to safely crank up the Boost .... which i dont have .......yet ;)
    • Can u check this way it works for power supply?
    • These coils draw 10amps that what i read online
    • I appreciate the detailed explanation, think I understand now. I spent the better part of last night reading what I could about shuffle and potential solutions. I had replaced the OEM twin turbo pipe with an alternate Y pipe that is separated further away from the turbo. The current one is from HKS and I had a previous pipe that was separated even further away, both have shuffle. I had heard that a divider can be welded in to the OEM pipe to remove turbulence, and figure that aftermarket pipes that are more separated would achieve the same thing. From what I read, most people with -10 turbos get shuffle due to their size, though it's a bit less common with -5s on a standard RB26. I think Nismoid mentioned somewhere it's because OEM recirculation piping is common in Australia with -5 cars. It seems that the recommendation tends to vary between a few options, which I've ordered in what I think is most feasible for me:  1. Retune the MAP or boost controller to try to eliminate shuffle 2. Install OEM recirculation piping 3. Something called a 'balance pipe' welded onto the exhaust manifolds. I don't know if kits for this are available, seems like pure fabrication work 4. simply go single turbo My current layout is as follows: Garrett 2860 -5s HKS Racing Suction intake MAF delete pipes HKS racing chamber intake piping hard intercooler piping,  ARC intercooler HKS SSQV BOV and pipe Haltech 2500 elite ECU and boost solenoid/controller HPI dump pipes OEM exhaust manifolds HKS VCAM step 1 and supporting head modifications Built 2.6 bottom end All OEM recirculation piping was removed, relevant areas sealed off I'll keep an eye out for any alternative solutions but can get started with this.  Only other question is, does shuffle harm the turbo (or anything else)? It seems like some people say your turbo shafts will explode because of the opposing forces after a while and others say they just live with it and adjust their pedal foot accordingly.
    • That worked out PERFECTLY! Thank you big time to JJ. He was able to swap me his stock diff. He drove all the way to me as well. Killer! Removal & install was pretty straightforward. The diff itself is HEAVY. So that’s a 2 man job.  Man does the car drive nice now! Couldn’t have worked out any better 👌
