  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
haha yeh i guess i am. yeh im really serious about his car. as soon as my mate micheal buys my car next month. ill be straight to the bank and giving shaun an offer. and if he doesnt want to sell. ill either have to see if i can get a 26 grand 32 gtr or get a r32 gtst and put 10 grand into it :D
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
