  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
i need everyones opinion!!
The SAFC II .... blue or ltd edt Grey?
http://www.greenline.jp/catalogue/btlist2....0and%20Monitors
normally wouldnt even consider grey cos blue is far prettier but theres two reasons why im undecided between the two.
A. The blue really sticks out and screams come steal me to anybody looking into your car .... where the grey is more camoflauged in with my interior
B. Its Ltd Edition so could hold its value more ..... but its not like im getting rid of my car nor going to go down the Engine managment path and need to sell it.
:confused: someone just make a decision for me pluheeez!!
well Greenline do both ... but slightly more expensive than Nengun .... although Nengun havent given me their postage prices yet.
How much do you think it would weigh for postage .... i worked out to be not over 1.25kgs ...... and i doubt its that even but i thought with the box etc ... about $450 on that ..... but it'll probably be less.
Nengun only do the blue and dont have special edition .... hmmm choices choices!! maybe i should just i draw out of a hat. Oh well if Nengun are cheaper then my mind i guess is made up for me :)
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
