  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
I had a dream there was a wild lion at my parents place so I like taimed it. But u had to be careful and make sure it didnt walk behind u or it might go crazy and attack you.
Then it went next door and chased the neighbours round
WHAT THE PHUCK DOES THAT MEAN
morning guys
i am in a spot of bother i left my best friends last night i got down the road and a dog ran out in front of me i hit it and then realised it was my best mates dog and it didn't look too good( hit at 70km/h ) took the dog to the vet, got a phone call this morning from the vet telling me the dog died. Sh!t what do i do :P
surely he would notice the dog missing after a day ..... & what was it doing out on the streets anyway?
Anyway Lee its a sad situation mate :P but im sure your mate will understand that it was an accident! :grouphug:
I gotta go!
    • With ordering the belt, you're doing water pump and the idler and tensioner at the same time too yes?
    • This is just a dumb way of keeping the wastegate closed to make more boost. Undo it and either follow the factory setup or redo it properly. Manual boost controllers just use a spring preload to determine when to close in response to boost pressure so it no longer vents to atmosphere.
    • So for the wide band is a Bosch 4.9 correct for the Link G4+ along with a Can bus? Just get the Link gear or is generic ok too? Eg here: LINK LINK DIGITAL WIDEBAND CAN MODULE WITH BOSCH 4.9 SENSOR : KYP Performance House
    • Bit difficult to follow. Have a look below and see what the standard R32 layout was like. Note there was a restrictor in place immediately before "turbocharged pressure control solenoid" that, if removed, magically got you 1 bar boost.
    • I might be way off the mark here.. there must be a T junction under the manifold. That takes manifold pressure through a check valve prior to the T, one side splits out to this bleed off orifice, the other straight to the wastegate actuators.
