  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Where a buck's enough to see their stuff, at the nudie bar.
Where the breasts may be fake but man do they shake, at the nudie bar.
Where you swear like a sailor, and wish you could nail her, at the nudie bar.
Where the cops are at the door, and there's a Kennedy on the floor, at the nudie bar.
1. It's okay to call hooters "knockers" and sometimes "snack trays."
2. It is wrong to be French.
3. It's okay to put all bad people in a giant meat grinder.
4. Lawyers: see rule three.
5. It is okay to drive a gas guzzler if it helps you get babes.
6. Everyone should car pool but me.
7. Bring back the word "stewardesses"
8. Synchronized Swimming is not a sport.
9. Mudwrestling is a sport.
Ok, mus finish my assssssssignments ....
Talk later :)
Where Christmas is nice, and lap dances are half price, at the nudie bar.
Where you drink down the shooters, and unwrap the hooters, at the nudie bar.
Where eggnogs are plenty, and the girls all twenty, at the nudie bar.
    • Did you panel beat the dents or have you tried to repair this only using filler?  Is your sanding block soft/flexible and is following the shape of the panel rather then just knocking down the high points?
    • I haven't knocked them down yet. I think I made the repair more complex than it should have been. I had rock chips combined with waviness and dents and I tackled it all in one because it was near each other and just end up wasting a bunch of bog lol. I'll knock down those areas and see how I go. And yep what you are saying at the end is correct. I think I might be sanding the top of a steep hill then my sanding block falls into the dent and gets rid of the guidecoat if that makes sense. Though shouldnt unless I'm covering too big of an area with not a long enough block. I'll try something new and provide some updates. Getting there though! Thanks as always.
    • Yeah makes sense, hard to comment on your situation without seeing what your doing. I was talking generally before, I would not be looking to randomly create low spots with a hammer to then have to fill them.  It's hard without seeing what your doing, it sounds like you are using the guide coat to identify low spots, as you're saying the panel is still wavy. I don't see how you're not ending up with patches of guide coat remaining in a wavy panel? Once the high spots are knocked down to the correct level, surely to have a wavy panel you need low spots. And those low spots would have guide coat still in them?
    • So I'll put filler past the repair area a bit to make sure I don't miss anything. Then I'll block it until it's almost level, put the guidecoat, then keep blocking until it's gone. Then it's still wavy.  In regards to hitting the panel, I saw this video might give more context - Skip to 0:47 he knocks it down. But yeah I'm sanding until the guidecoat is gone then checking because otherwise my filler is still well above the bodyline. Unless what you're saying is I should put guidecoat around it early, surrounding the filler then stip once it's gone?
    • I refreshed the OEM injectors with the kit and connected it up. It now ideals okay even with the IACV removed. Driving still has the same cutoff issue like the 550cc injectors so the issue is somewhere else. I bought FPG's Fuel Pump Hanger. I will be installing it next, but it is not as straightforward as I thought it was with my limited wiring knowledge and no instruction on the specific model I purchased (FPG-089). I also got the incorrect billet clamp as I could not find info on the OEM sizing.
