  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
mandurah is ok :)
oi guys guess what, i found someone selling 2 enkeis the same as mine in some other country... i emailed him saying are you still after 2 enkeis coz he had a wanted thing on a website and he said i got 2 and they were the wrong size (my size) so that worked out awesome. hopefully i will be able to fix mine but if i cant then its a good back up...
this is good news... :D much happier now hehe
dropping off the mags tommorow as i said and i'll see what they can do. :)
