  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
hehe i always wanted to be michael andretti :)
but yeah i understand ur point Ken - i say lets find out one day soon :D
Hehe , 21 was when I thought I was invincible..
Was rallying an RX7 and came 5th or 6th in the State Rally championship that year.
Took a MUCH older guy to prove that balls and bravery were no match for age and experience.
Lets just say that after navigating fo the dude I realised that a WA championship win was a distant hope.
btw the dude was Ross Dunkerton and we came 2nd o/r
Cheers
Ken
Ross is a legend in his own right you must look back at that with pride
seriously all this talk has made me wanna find out what i can or cant do in a car ....
ill have to get details asap
31/01/04 is the next training day.
$100 , 12 people for the morning and you get the best (hehehehe, ok , you get me) and if you pass , the mc drift series is your oyster.. :D
Cheers
Ken
nah no thanks im not a drifter not my type of thing
... got anything circuit style going ?
Tom , very expensive running a proper training day at Wanners but will be running for our client base ( that's Hyperdrivems) a late afternoon midweek at the new MC airport venue series where costs are minimal and you get my tuition for a few hours...
    • A 1.5 way is a 2 way. It is just a 2 way with a less aggressive ramp on overrun.
    • The ABS and/or TCS being missing/broken will not cause the engine to misbehave. It just casues CEL to come on and annoy you. The CEL is useless if it is always on, so you have to do the things you have to do to get rid of it, so it can be useful. Being a Stag ECU, then yes, it will not expect TCS to be present. But it will expect ABS to be present and working. You will need to either make the ABS CU talk to the ECU (don't ask me what that will take on an NA R34), and make sure the hardware is working....or, you just need to blank it out in Nistune. Do not persist with the stock ECU. You will just have problems. Gte it Nistuned. Start from there. DO YOU HAVE A BOOST SENSOR? The ECU's boost sensor that it. It is connected to the loom at the rear of the coil cover. Usually rides on the firewall on an R34, but is usually bolted down to a bracket along with all the other crap at the back of the coil cover when a Neo is dropped into another car. If you do not have it, the ECU will shit the bed. So, do you have one?
    • So sadly the fuel pump etc was not it. The pump and filter is new and it is still cutting around 4000 rpm. A read something about ABS/TCS (engine is from stagea and ECU too so no TCS) and i dont know for 100% that my car has ABS. It has ABS "cube" in engine bay but i dont think it works(or at least from my braking experience). Can be something like that?  I will be driving the car next week to Nistune tuner to properly see what is wrong...
    • the Tomei LSD fluid with lsd kit. frustrated that it was shaking the car to crap and affecting everything else negatively, I pulled the diff last night, and removed the lsd carrier, could not find anything wrong, however it seem to be 100 locked up acceleration, and deacceleration, wondering if they sent me a 2 way not a 1.5??  either way I installed the stock open carrier back in place. test drove everything smooth as butter again. no shake, shutter, random, what felt like clutch slip and grab or drive shaft play, etc. something differently wrong in side the lsd. I might bother taking it apart (if possible) to figure out what's going on inside this carrier, as bought too long ago to return.  only draw back is its back to a one wheel wonder.
