Is that invite universal kenny or just for the girls:bahaha:
I came past today but you guys must have chickened out already...that printer of yours was making a racket rolling around in the boot of my R
Today Micko ??
Mate I always go to a mates place on Boxing day , get in the pool with a few close friends and get well burnt/pissed .
Will be there at 7.30 am tomorrow and come around if you want.
We need someone to barrow the cubic metre of waste concrete :D
Lauren , I don't get jocks from the wife but she now owns 1/3 of a dyno/workshop so I suppose that's her/my present.
What did you get apart from bored ( as in no excitement, not screw..ohh never mind ) :)
Cheers
Ken
  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
And as far as the R33 goes, just call me moby , as in whale.. :D
The R is gone and the current budget does not allow for a 4wd replacement so am building an angry R33 GTS-T which used to belong to GTS500 ( aka Danny).
Have a few plans for it and will have some fun dragging/drifting/MCing/SESing .
2wd and 400rwhp should be fun :) :headspin: :headspin: :headspin: :aroused:
Cheers
Ken
lol 7:30??? .... :coffee: :( ..... tell him he's dreaming - a girls gotta have beauty sleep :) 10:30 would be a better estimate :(
i can barrow .... but i wont be wearing a short skirt :)
1/3?? now she's got your balls in a vice :D
$300 worth of bills paid .... $400 for SAFC ... but because of unemployment thats all gone into surviving .... now down to last $200. Makeup um yeah just bits n pieces.
7.30 was for Micko, your 10.30 am will be fine but bring your oktoberfest outfit as promised.
We will be hungry and thirsty by 12...
* Joking Niz , just joking..*
Cheers
Ken
yeah Micko working on replacing it .....
thought Free Willy was better? LOL
thought the one in Danny's doesnt have a motor?
At my age I will even pay for someone , let alone have a free one...
Yep , it's got no moter which will be 1/2 the fun building/sourcing/developing/blowing/redeveloping one for it :D
Cheers
Ken
lol yeah Lumpy said forget the oktoberfest outfit .... nothing would be fine :D
thank god 7:30 was for Micko - dont think my body could handle that kinda shock.
We could always come around and give you a wake up call :)
Cheers
Ken
lol ..... its not a good sight in the morning .... thought Adelaide wouldve proved that :D
Couldn't see you hidden under the doona/wookie hair. hehehee
* sigh , still can't work out why this girl thinks she's ugly/fat/undesirable to the opposite sex :aroused: *
Cheers
Ken
trust me .... i moult more than the wookie. What happens when ya bleach ya hair to buggery.
i dont know .... just me i guess ..... i go thru these really intense up down periods .... at the moment im back down ... im just going insane in this environment :crazy:
    • Ok i will get those 310mm. I found one but on a different site. This is the description on those...is it ok? Technical parameters: - Axle: front. - Disc type: ventilated. - Number of holes: 5. - Disc diameter: 310mm. - Total height with center: 54mm. - Thickness (new/min.): 30/28mm. - Designed for brake calipers manufacturer: Sumitomo.
    • You Gregged a whole racetrack!?
    • Look for broken wire or bad connector at the motor. Might not be it, but is worth starting there, as it is easy.
    • Hi everyone, I’m having an issue with my R32 GT-R. Sometimes, when the car goes over a bump or experiences some vibration, the 4WD warning light comes on the dashboard. When I check the code from the control unit in the trunk, it shows Code 19 – ETS Motor. However, everything seems to be working fine — if I turn off the engine and restart the car, the light goes away and everything functions normally. Has anyone experienced this before? Where should I start troubleshooting this issue? Thanks in advance!
    • I'm back from the dyno - again! I went looking for someone who knew LS's and had a roller dyno, to see how it shaped up compared to everything else and confirm the powerband really is peaking where Mr Mamo says it should. TLDR: The dyno result I got this time definitely had the shape of how it feels on the road and finally 'makes sense'. Also we had a bit more time to play with timing on the dyno, it turns out the common practice in LS is to lower the timing around peak torque and restore it to max after. So given a car was on the dyno and mostly dialled in already, it was time for tweaking. Luis at APS is definitely knowledgable when it came to this and had overlays ready to go and was happy to share. If you map out your cylinder airmass you start seeing graphs that look a LOT like the engine's torque curve. The good thing also is if you map out your timing curve when you're avoiding knock... this curve very much looks like the inverse of the airmass curve. The result? Well it's another 10.7kw/14hp kw from where I drove it in at. Pretty much everywhere, too. As to how much this car actually makes in Hub Dyno numbers, American Dyno numbers, or Mainline dyno numbers, I say I don't know and it's gone up ~25kw since I started tinkering lol. It IS interesting how the shorter ratio gears I have aren't scaled right on this dyno - 6840RPM is 199KMH, not 175KMH. I have also seen other printouts here with cars with less mods at much higher "kmh" for their RPM due Commodores having 3.45's or longer (!) rear diff ratios maxing out 4th gear which is the 1:1 gear on the T56. Does this matter? No, not really. The real answer is go to the strip and see what it traps, but: I guess I should have gone last Sunday...
