  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
someone buy me a bullet ......
Thanks to Dan ..... my supposedly quite little New Years Eve saw me getting home at 7:30 this morning .... yes i blame Dan :Paranoid: its all his fault :(
It's nearly 12:30 and we are only getting ready to go to Perth Cup now .... thank god for a hat n sunglasses!
thought i would pop in before i crash ...... big time ..... sooo tired. Managed to get through Perth Cup - so boring .... too poor to bet ..... too hungover to drink so there was bugger all to do really but get hit on by yukky old men.
Anyway enough of my tired barely making sense ranting Happy New Year Everyone :)
Thanks Aidwin :grouphug: .... i need it. Hope you had a good new year and xmas and look forward to catching up with you when you get back :)
Anyway im off to bed now :) See everyone in morning/early arvo. Night!
    • Despite the level up question, actually I do know what that is....it is a pressure sender wire.  So check out around the oil filter for an oil pressure sender, or maybe fuel pressure near the filter or on the engine. Possibly but less likely coolant pressure sensor because they tend to be combined temp/pressure senders if you have one. Could also be brake pressure (in a brake line somewhere pre ABS) but maybe I'm the only one that has that on a skyline.
    • Pull codes via the self-diagnosis procedure. As far as I can tell this is just a sign of transmission issues but not a code unto itself.
    • Hi All, putting the engine back together and everything is perfect except have this plug left over.. any ideas what it is for and where it goes? Is on cold side under the intake plenum *note not a stock plug, as everything has been modified Cheers
    • Sounds like a misfire. Check fuel pressure and don't even think about going into boost while it's like this unless you enjoy engine rebuilds.
    • Just. Gasping. Here. Just. Gasping.
