  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
if so can your workshop install stock spring on a r33 skyline (93 model)
if yes just pm me cuz im off now later
*Sigh *
Right you lot.
pwptpf is dead cos I am gonna kill him.
Mike , your noob posts and phone calls are no different to everyone else who rings so don't feel bad.
All exhaust pipes are black since they removed the lead content in fuel and the smell is probably a bad seal at the filler neck.
yes we have spring compressors and can install stock springs. we even have a set in stock if you don't.
The dyno will be running by the end of the week and we can check your a/f's then or we have a mobile a/f and can take it for a blastif you want to bring it around.
Nothing we do is for free but we try to look after SAU members the same as SST.
Right , any more ****ing questions ?????hehehe
Cheers
Ken
I have a question, but I don't know if its really relevant here.
Why does it hurt when I urinate?
(Ignore me).
YOu could have a Urinary Tract Infection (bladder infection). You should see a doctor as they will prescribe anti-biotics. It is diagnosed with a urine test.
Drinking lots of water can help flush out the infection as well. But in men - because the urethra is longer than a females - there is more chance of the infection becoming more severe. So if drinking lots of water doesnt help - see a doctor - because the pain will become unbearable.
Or you could have an STD...... such as Gonorrhea - which has similar symptoms to a Urinary Tract Infection (frequent and painful urination - is one symptom)
from nursey liz
    • Hey keep the ideas coming, I'm always keen on projects! But, problem fixed!  I got a cheapie ozito scope from Bunnings and had a good look in and around the bearing and sensor hole. I couldn't see a smoking gun but the bearing looked a bit strange, especially when comparing with a new one. I thought the cover had come off the bearing magnets.  Sorry for pics of a screen, I didn't have an SD card.     Good thing I had the old one to inspect. So, given I'm like a pit crew with wheel bearings and luckily I had a spare bearing because I f**ked up my parts order, I decided to just smash it out. Got the old one out in about an hour. So much easier when the parts haven't had a chance to rust together yet. 😂 And, well, found the problem.    In the second pic at about the 8 o'clock position, you'll see what I think is the tip of the old sensor.  The new sensor has definitely been rubbing but it's all intact, just a little shiny so I'm hoping it's fine.  The car brakes perfectly now and no errors.  I think the job took about 2.5h in the end. 👍🏻 I really appreciate the help in here as usual. Thanks guys.
    • I was only looking because I saw some drops on the ground but it wasn't alot. Recently had it serviced will ask the mech to confirm. Find it strange that it looks standard though, can see in another photo of a random box
    • So...not sure if you know if that has always been there or why you went looking. It could be old damage from a clutch explosion, or even just the gearbox got dropped somewhere along the line. Basically, you should seal it up to stop oil and dust getting into the bellhousing, but it doesn't matter too much and is not structural. I'd suggest something like a glob of JB Weld. BTW what gearbox oil are you running, I would guess the breather has been spewing it everywhere.
    • Hey Duncan thanks for your reply. Sorry mate I know the photos are shit.  Took another photo for reference. Seems the casing does have a hole in it looking on the net, fluid seeping out. Added a photo
    • Very hard to make out what you mean, is it the squarish hole with redline shockproof (probably) under it? Is that pic from on top of the engine with the firewall to the left of pic and engine to the right? Either way, spray the area liberally with degreaser and try again, maybe circle the part you are worried about
