  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
yes i do paul :( ... feel sorry for me .... in that horrible office with all those fat pricks :spew:
yeah while the weather is good .... wait til my folks go to bunbury and i might have to break out the ZX .... wanna drive?
joe ...... ask jared .... he's had a ride in it ..... sideways thru a set of lights in the wet .... instead of freaking out like you he thought it was huge fun. P.S: lights were green at time. Very hard to get traction in that car in the wet :( and its got Toyo Proxes tyres on it!
