  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
what lights problem ..... im more of a shit stirrer than an person that sorts out technical problems.
Day well this guy (client) came in today and he asked me how my New Years was ..... then after knowing him 15mins he proceeded to tell me how he went to Perth Cup with a Stripper that finished work at 6am .... and the love of his life that has a 10yr old that lives in Bunbury found out so now she's told him t shove it .... Wha tha? i didnt ask for his phucking life story!!
saw it Mike .... cant help ya mate .... but you get used to the fact that theres never a time where your car is running perfectly .... always something you need to fix.
joe - good to be back at work eh?
odo stopped ticking over
overfuelling like a bitch
brakes squeel terribly
front spoiler has become unsealed n loose in passenger side again
my drivers side rear rim has been scraped
the centre console lid is broken
when it idles it splutters after a while but all i get is ... well its leaking somewhere but we dont know where.
its well overdue for service .... been like 8 months since last service
its fuel warning light plays disco and flashes on n off when you first fill up tank.
Would you like me to go on ..... or do you get the picture!
ok problems
1: Park Lights Broken
2: Brake Light (in S2 wing) Broken
3: Fog lights Broken
4: Front Bar Crack
5:Crack In Brake Lights
6:Front Headlights clips broken
7:Car Running Lean
8:Need better alarm
9: Need stock springs install
10: Sub need 2 be fix in
hmm that is all i can think of for now
well i dont even have an alarm :D
and my amp is roaming around the back of my car cos strahtfield did a shit job of mounting it .... subs all roaming around the back freely cos paul had to disconnect it all to get to fuel pump.
Missing my engine cover too paul! :mad:
and all those light problem hould be counted as one :mad:
PS - you car is not running lean you havent even put it on dyno and plus your running stock boost.
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
