also last time i parked in the city ive phucked one on my rear rims on a huge curb ..... there was a real tight turn and yeah .....now ive got rim repair to add to things to do to my car.
  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
alex you got a girlfriend keep it in your pants ..... nothing shits me more than when a guys walking past with his girlfriend and he's perving on you ....... guys are nothing but phucking slimeballs.
there is nowhere else ..... i have a choice
$16 a day
or......
Out the front of the drug rehab clinc near the childrens court .... so i can pay a fortune or i can come back and probably not have a car.
i should be getting my rear spoiler soon ..... guy wants to have lunch with dad tommorrow - dad wants to discuss my wing he wants to discuss his house .... he aint getting the work to his house til i get my wing!
That should give me some cash when i sell my GTR one ... should be able to straighten out a few problems wiht my car after that.
