  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
yo its GTR aka Nismo
b1tches dun want me for me, but they want my great gismo
yeh sure i got no car, but ill whoop yo ass in grand turismo.
WASSUP PPLZ
im so ****ed i didnt go to uni today cos my ****en family ****en forgot bout me that i ****en need a lift to d ****en station cos the ****en closest station is ****en closed and now i missed my ****en test and im ****ED!
