  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
hello i survived my job interview :) i probably find out this arvo
My friend was racing me in her Hyundai Excel last night - was so funny - she gets so determined its like the "little engine that thought it could" so i stopped in the middle of tonkin hwy waited for her to catch up and get in front of me and then floored it to 150km and she was so determined to keep it up. Funniest thing a Skyline and a Hyundai Excel racing down Tonkin ..... bit of an odd couple.
Paul warned me not to thrash my car ..... now im having trouble getting it started :) It wont tick over and at the slightest sign of life i have to stick the boot into the accelerator to get it going.
Thanks Lee ..... i feel confident but still they might think im overexperienced. But it would be cool cos i really want to get into the events department there ..... you think the Turf Club also does the Ministry of Sound and Car Events at Belmont Park :) Only bad thing is i would have to work New Years Day.
yeah i pretended i didnt know what they were talking about when they mentioned Ministry of Sound dance parties ....... i felt like saying "You barsteds dont even hold them at Belmont anymore"
thanks Aidwin ..... im thinking of putting dual gauge pillar in there cos they look spunky! Just need a boost gauge ..... and whats another good gauge to have?
Ouch has PM's me he's interested in selling his zorst system cos its too loud and he's interested more in stereo ... so i wanna have a look at that cos it sounds like exactly what i need. I see all my funds going into my car at the moment. Rep has given me some really good ideas too.
Yeah it is unusal and worrying that my car isnt starting first go - sometimes it starts fine but lately its getting worse n worse and i dont want to damage it but starting it the way i have.
:) my friend just emailed me and said "If ever the cops were chasing you at night theres a fare chance they wouldnt see your number plate" cos she didnt think it was my car last night she looks n goes "hmm i wonder if the Silvia is going to race that other Nissan" .... "hang on that nissan looks like laurens .... nah its blue and she couldnt see the plate til she got right up close.
    • Harness is for a s1 Rb25det, and it is engine and lower harness.  the old harness had broken off plugs and was in very rough condition/exposed wires and splices etc. it is not able to be put back on the car, I could visually inspect to see if they had rewired any pins on the ecu plug. The fuel pump definitly isn’t turning off it’s an external pump and very loud you can hear it. Will look at the other harness tonight, am also going to pull the fuel rail and watch the injectors spray, will update here with what I find. Pretty sure at this point it has to be something to do with injectors because car will fire up on starting fluid and cas is clicking the Injectors. Fuel pressure is steady 43psi
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
    • I haven’t pulled the injectors to watch them spray yet but they are clicking from the cas and all of the spark plugs are wet with fuel. I’ve thought the cylinders were being flooded from the beginning and was hoping fuel pressure would fix it. Tonight I am going to pull the rail and watch the injectors spray. Don’t know how to test/diagnose if the plugs are firing in correct sequence but that should be a timing thing and as far as timing goes my car still has the half moon for the cas can only install it 1 way. And my mechanical timing is 100% correct I posted photos above. Confirmed with the balancer on and off.
    • I checked spark on all cylinders and they all visually have spark with the plug pulled and grounded, but plug 1 is the only one that fouled. This was a running swap that blew up and was rebuilt by a machine shop, put a new wiring specialties harness and did all gaskets, studs, and bolts while it was out.  compression is 135-150 across all cylinders. Aside from that from my understanding with the z32 ecu and maf the car should start regardless. The wiring for TPS and the dual 02 sensor/ dual knock sensor stuff shouldn’t actually stop the car from starting or even running well, (just slightly rich)  they just give fault codes. Car supposedly is supposed to start as long as you have z32 afm and ecu with the nistune base map and that’s info coming from a well known and trusted tuner who does a lot with SR/RB (Rsenthalpy). After more trouble shooting today where I’m at right now is that the cas is sending signal to the injectors they click while spinning the rotor, Fuel pressure is now set at 43psi, all cylinders have good compression and all of the plugs looked great (just wet with fuel) except for cylinder 1 which was very black (cylinder 1 has 150psi compression). all of the coils generate spark if pulled out and grounded out on the head. On the fuel pump car just pops into the exhaust. On starting fluid car will fire off. Hard to tell if all cylinders are firing off but definitley a couple. sounds like all of them but it’s only for 3-5 seconds hard to tell.
