  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by GTS-t VSPEC
No, no. We all relalise one session won't make us car gods, but it's a step in the right direction. Hopefully it might scare some sense into us, so we realise our limitations:D
See'ya:burnout:
I am going to speak with John and see if there is an arvo session.
If not , will make a decent day of it for the same money.
Hope you have plenty of fuel and some crap tyres.
cheers
Ken
Ken, no, it's the proper stuff from Japan, the D1 Drift, with all the top cars. I'll let you borrow my copy:D
See'ya:burnout:
D1 drift
pfft
How hard can that be , throwing it the wrong way towards the wall at 120kmh , drifting around the closing radius corner and swapping back the other way without spinning.
could do that with my eyes shut ( cos I would be screaming in fear).
Cheers
Ken
Yes, Joe is a moderator at it's worst:D
Are you doing anything tommorow?
See'ya:burnout:
Moderator ???????????
yea , Riiiight
Tomorrow in the morning is busy and then am avaliable for consultation about lunchtime till 3 pm.
Why , we vidding at Mackas cos it looks like Micko has piked.
Cheers
Ken
Yeah, I'm impressed at at how fast they drift the corners, but there is alot of damage done to some of the cars. You have a DVD player right?
See'ya:burnout:
Yes , have a dvd but may not be able to play copies.
cheers
Ken
See'ya:burnout:
Rule !
Don't EVER race , rally or drift what you can't afford to throw away.
Master crasher has spoken.:)
Cheers
Ken
Micko is a p u s s y:D
I'm at a birthday till about 2:30, then the V8's are on, so maybe we'll organise a vid day next weekend over at Macka's. He'll be keen if I supply the beer:D
See'ya:burnout:
Hmmm , that sounds like a go .
Will check the calender and the brownie point allocation
Cheers
Ken
Hehe, yeah, but it must still hurt when you wreck a car:D
It's a VCD, worked fine on my DVD player and my mates:D
See'ya:burnout:
Mates.
Ya got mates ?
btw , next w/end is Easter.
cheers
Ken
See'ya:burnout:
B/day , what , ya nieces 8th ?
Cheers
Ken
Ken,
Just don't use the brownie points on anything else:D
Are you going to the PPCC cruise on May 4th? Or will you be away?
See'ya:burnout:
Will hopefully be here and will try and go.
Is always worth it when Mandees there. lol.
Cheers
Ken
Guest
    • Hi guys, just after some guidance with an R34 sunroof that has stopped working correctly. It still opens and closes perfectly fine, but it no longer tilts/vents up or down. As a result, the rear of the glass now sags a bit as it drops down slightly in order to retract into the roof, but now it can't pop upwards into a flush position. I’ve probed the pins on the back of the switch connector with a multimeter and it seems like both switches (for open/close and tilt/vent) still work correctly. Any ideas on what it could be, or where I should even start in terms of diagnosing? I'm sure someone's had this issue before but I haven't been able to find anything online relating to this specific issue, most of the issues are with the seals leaking or the motor failing entirely. Thanks in advance!
    • Do you have some data like fuel pressure? It's really hard to say if you're still fighting a fuel system issue at this point. Could be something weird like the FPCM dipping out.
    • Yeah in that case, pulling the dent out. Event a very slight dent can create a lot of work filler-wise and there is a strong chance the panel won't be the factory shape when you are done (as the dent will result in a new high point created somewhere, then everything is brought up to that new high point... but the panel shouldn't be that high if that makes sense).  So you've filled and primed the panel and it is flat, why would you go back and remove the primer and add more filler?
    • Something else I have been faffing with while the car was off the road is making the AC work. Assuming the car isn't at a thermal limit the idea of having AC while waiting in line to go on track sounds delightful. I have actually been lugging around the weight of the entire system since 2018 when the RB25NEO went in without it working at all.  The main reason was in the first few events before I got around to re-gassing it the rubber hose that runs under the manifold had the factory heat wrap/sleeve fail resulting in this: ~2 years ago I purchased a complete used R32 AC line set but when I finally went to install it the line i needed was different where the expansion section is I found a local place that was able to replace the rubber section and re-crimp. They also added some modern heat sleeve to the hose Tight fit but fingers crossed this is the last physical piece of the puzzle needed
    • the top black section is bonded to the silver section with some form of rubber. I assume to isolated NVH from the box
