  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
I've changed my home loan from a std 25 year mortgage to a offset/equity loan. I bought the house 2.8years ago for $85,000 its now been valued by the bank at $110,000. I've got the loan down to $70,000 by paying a bit extra each fortnight for the lasy 2.8years, so I've taken a low offset/equity loan at $82,000. So I've got a bit of extra cash lying around incase I need it, but cos its an offset loan I should pay it off much quicker than the std 25 year loan. Its a bit confusing but I sat down and did the figures, going as I was the 25 year loan would be paid off in another 12 years with the new offset loan it'll be closer to 3-5 years depending on how frugal I am, quicker if my wife gets another job too :( Stupid education dept wont give her a job in the metro area :P So yeah, we want some french doors to open out onto our courtyard and I want to do more work on the car :)
Powerfc will set me back around $1700 delivered new with controller, then plus fitting and tuning. The autronics is $3500 drive in and out, but has boost control built in (if I want to sell the blitz sbc will make the install cheaper), traction control, serial port connection to a laptop with easy to use PC software so I can **** with maps when I know what I'm doing.
Guest
    • Can't you put the pistons to TDC and then do the valve seals? Or will the drop down too far to pull them back up?
    • One thing I can tell you is, do it properly the first time. If you encounter unexpected problems just let the car sit for a week or two if you have to get some other parts or figure stuff out.  I'd have said go and use as many OEM parts as possible but since you want to change the turbo later on a custom kit is probably the better choice. Since I have no experience with RB25 just compare parts diagrams and images before buying a line kit and it should be easy to see if it has everything you need. Amayama has very good parts diagrams and part number lists, that is what I used a bunch to figure out what I might need. And don't forget to plan ahead and possibly renew other stuff that's easy to get to while you're in there doing the turbo lines. Happy wrenching
    • Update 4:   Hi all, good news. Engine is running and all the gaskets and seals seem to be working as intended. No leaks so far, even the JB Weld seems to hold. I flushed out the old coolant a few times and put in fresh coolant, not Nissan stuff, I decided to try the Ravenol Protect FL22, they claim it works for a wide variety of JDM cars and the opinions on it by some people were pretty good. And it has the nice poison green color! And man am I glad I bought a coolant system tester earlier this year, vacuum filling works wonders on this engine. I can definitely recommend this to anyone still doing it the old school way. All you need is compressed air supply. Will have to do a small test drive as soon as I can, I removed the gauge cluster again as the tacho needle was still bouncing around a bit but it was much better than before already.  I also found some cracks on all 4 tires inner and outer sidewalls. Apparently these tires should 't be parked on for extended periods or be kept under 0 degrees during storage, which I did not know. Clearly the previous owner didn't look into those details either, he probably bought them just cause they are cool semi-slicks. I'm just wondering how tf I am supposed to reach 30-80 degree tire temperatures on the public road consistenly, these tires were never going to work for my use case. I'll probably order Continental SportContact7 ones as these are the best allround summer tire available right now and I don't think I'll need anything crazier for now. Do let me know if you have experience with various tires and which ones you recommend.
    • You have no idea how many goddamn boxes I received these past three months haha Most have been put to use by now though, luckily
    • Not going to pretend I didn't do a bit of junky work this time around, but mostly due to the fact that some things I am not willing to spend days fixing right now, like wiring. I try to do most things properly the first time around.
