  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
met angel last night. she seemed quite nice.
had an awkward moment.
"Hi Im alex"
"err.....right. Hi Im Angela"
"You here with Rollaboyz?"
"No. A Skylines club called SAU"
"Oh, cool.........are you a forums person?"
"yeah, Im Angel."
this is the point where it registers why angel is angela and visa versa. I think to myself that I should tell her Im zanda on the forums, but Im still really thinking about the nickname/realname thing; so out comes:
"oh, cool....I'm Alex"
"um.....(thinks - is this guy a nutter or what? wtf?)..Hi, Im angela"
*unneasy silence*
*alex considers cutting his losses and doing a runner*
"duh.......I mean Im zanda on the forums.....urgh!"
"oh. cool."
*mental note, dont talk to zanda on the forums*
Haha
Originally posted by Boostzor
Defination of Car: hole in road in which to throw money.
Definition of boat: Hole in water in which to throw money
definition of a woman: something else you throw money at. You think there's probably a hole in there somewhere, but you probably havent seen it yet.
better keep throwing money at it! :D
Guest
    • Have you confirmed its the actual axles? Also the wheel bearings that mount on the hubs to hold the axles wear out. I replaced mine as they got play in them. It sorted my play issue.
    • Ive converted a few clusters for the R33 with 320km/h dials. On the back there are some pads which can be bridged or unbridged (using solder or wick braid) to calibrate it. There is one bridge which is for MPH <> KPH; and there are combinations of bridges to offset it. There is probably a diagram  For example; this is my conversion for a 180km/h dial to a 320km/h dial (I put custom GT-R dials on it with the GTS25t layout) If you have J2 soldered (assuming the S clusters have a similar config to the R clusters); you may need to remove that solder
    • Back on topic 😉, these are some of the notable pages from the booklets that are supplied with each weekly parts update. I never knew the BNR32 test mule car had an S13 Silvia body...
    • This. A 3d wheel alignment is like $120...just take it to the shop. Since theres probably multiple adjustments that need to be made after changing something. Mine has front/rear lower arms, traction rods, tension rods, camber arms, toe arms, front upper arms, hicas kit, sway bars and coilovers. I measure from the edge of the bolt holes on the originals and set the same length on all the adjustable stuff to dial it as close as I could to OEM. Took it straight for alignment; it didnt feel right at all...after alignment, it feels perfect. Similarly i've just changed the springs on another car; and I still needed multiple adjustments to bring it back in spec.
    • A full Veilside kitted JZA80 Supra in Meriken park in Kobe city a few weeks back
