  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
A camel and an elephant meet. The elephant asked the
camel, "Why do you have your breasts on your back?"
The camel, clearly irritated, replies, "What a silly
question from someone who has his dick on his face."
TOP 10 REJECTION LINES GIVEN BY WOMEN (and what they actually
mean)
10. I think of you as a brother.. (You remind me of that inbred banjo-playing geek in "Deliverance.")
9. There's a slight difference in our ages.. (I don't want to do my dad)
8. I'm not attracted to you in 'that' way.. (You are the ugliest dork I've ever laid eyes on.)
7. My life is too complicated right now.. (I don't want you spending the whole night or else you may hear phone calls from all the other guys I'm seeing.)
6. I've got a boyfriend .. (I prefer my male cat and a half gallon of Ben and Jerry's)..
5. I don't date men where I work.. (I wouldn't date you if you were in the same 'solar system', much less the same building.)
4. It's not you, it's me.. (It's you.)
3. I'm concentrating on my career.. (Even something as boring and unfulfilling as my job is better than dating you.)
2. I'm celibate.. (I've sworn off only the men like you.) and the number 1 rejection line given by women (and what it
really means)
1. Let's be friends.. (I want you to stay around so I can tell you in excruciating detail about all the other men I meet and have sex with. It's that male perspective thing.)
Top Ten Signs Your Relationship Is On The Rocks
10. Her term of affection for you is "You Bastard."
9. She shaves your eyebrows off while you are asleep.
8. She rushes to answer the phone each time it rings, and puts
it down with a hushed, "I can't talk now... I'll call you later."
7. Your picture on her wall has darts in it.
6. She reads books like "Women are From Venus, Men Are Complete
Assholes."
5. She falls asleep during sex. The oral kind. While she's
giving it.
4. When you call her, she answers your voice with, "Oh. It's
only you."
3. She cancels your date because she has to clean out the
septic tank.
2. She makes inquiries about going on the Witness Protection
Program.
And the Number One Sign Your Relationship Is On The Rocks...
1. Her cat pees on you. And receives a reward.
I REALLY MUST RE-TRAIN ZENAH (my cat) !! :P
Guest
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
    • Is it alright to top up with just another green coolant?
