  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Ahh buggered if i know, its running on all four now which is good but low and behold after its maiden run i open the bonnet and there is oil all over the place. there is a leak somehwere near of behind the CAS cover and its spraying all over.
The coke bottle worked good though ;)
Hopefully ill take of teh CAS cover and there it will be some little o ring or something taht obviously need replacing. Either that or a big crack down the side of the block :eek: might need an engine upgrade :eek1:
Yeh that is where its coming from. Ya know the little oil breather box thingy? we we ripped that off and replaced it with a CPU heatsink (dont knock it it works) and from the little gap next to it u can see it all come out. Alot of smoke too
hmm well im not at home and i dont have adigcam so there are afew obstacles.
Ya know the valley with all the plugs and crap? well there is a little flat bit of metal on one side and a little box that sticks out of the rocker cover and joins the breather pipes from the intake to the ahhh other thingy. yeh that part
Guest
    • Possibly avoid using a Cometic one unless the deck/head surface are perfectly flat. I did have a look just then and forgiving gaskets such as Tomei or Nitto don't exist for the FJ20, however the Bar-Tek or Kameari ones look good and might do the trick.
    • Because pipe threads for pipe things. M threads for bolt things. Throw some teflon sealant onto it and dust your hands off knowing you did the right thing, instead of going twice around the block to achieve a result using the wrong things. Of course, all of these solutions are ignoring the fact that the minimum thread pitch we're talking about here is 1.25mm, with the 1/4" in NPT or BPS being out around 1.4mm. You will need to know that the boss you're tapping has enough thickness for at least a few threads. That's one of the reasons that 1/8" is commonly used - because the pitch is <1mm. And why would you look to use 1/4" NPT in a BSP country anyway? Ugh.
    • Just throwing around ideas, does it need to be in the compressor cover? Why not the hot side piping?
    • 1/8NPT drill size = 8.7mm. Since the hole got messed up by me, it’s probably around 9mm.    So 1/4” NPT would be next step. A drill size of around 11mm would be preferred there which is not way of my M12 (drill 10.5mm and tap M12 threads)
    • 3 Kids are starting to hit that ages. I wanted to get them something special to learn on, put down the screens and have some fun. 4Door 2001 R34DE Black Pearl GV1 Jap Import, AU 2nd owner. Pre Work done. Suspension - Wheels Pedders SportsRyder Coilovers   Wheels TSG Spokey Boi 18'x9.5"+15 Body JASI Aero 4 door Type R Full Kit LED Conversion - Parker, Blinkers, & Reverse Exhaust Hurricane Headers 100 CPI high flow cat 2.5" Piping Cannon muffler Internal Bride low max stradia ii - front seats  Bride RO seat base and Rails (R/H) Cube short shifter LED Conversion - Interior
