Sup guys
just wanting to know
if it is better (get more Power) driving automatic gtst with overdrive on or off?
at moment i am driving with it on
is this correct?
or is it better to have overdrive off? stoopid lil orange overdrive off light lol
thanx adrian
:burnout:
https://www.sau.com.au/forums/topic/8842-overdrive-off-or-on/
Overdrive is like an extra gear for the auto that was designed this way to reduce fuel consumption on the highway the main reason that people leave it turned off in town is because you need to get to between 80 or 90 kph before overdrive kicks in!
And if you cruise at around 80 - 90k's (mine changes as low as 70kph sometimes) the overdrive can change in and out of gear (rather unecessary at this speed) and this constant changing between 3rd gear and overdrive severly wears out the overdrive!
MEGA
P.s PVA-glue towing a trailer or having two chicks in the car is not a good reason to use the overdrive! (and you wouldn't benifit nothing from it unless you were doing more than 80 - 90 k's) maybe your thinking of the power button (this changes the rev range at which the auto changes gear (redline gear changes if under heavy acceleration) and also early drop-down which can be quite fun! The hold button just makes it so that under hard acceleration the auto won't drop-down a gear!
MEGA
Exactly right....I was going to type something along those lines but I couldn't be stuffed. :D
but i still dont' see why people would want to drive with it off .. i mean the revs are much higher ... maybe about 600rpm or something like that which is really noticeable ... which means you could stay at the same speed at a lower rev and therefore be more feul efficent ... so why the recommendation to drive with it on around town?? i only ever turn it off if i want to go a bit faster.
Read this. Posted just above by MegaGTS4.
Overdrive is like an extra gear for the auto that was designed this way to reduce fuel consumption on the highway the main reason that people leave it turned off in town is because you need to get to between 80 or 90 kph before overdrive kicks in! And if you cruise at around 80 - 90k's (mine changes as low as 70kph sometimes) the overdrive can change in and out of gear (rather unecessary at this speed) and this constant changing between 3rd gear and overdrive severly wears out the overdrive!
ok i will do a test ... i have to fill her up today anyways .. i will use my normal petrol as i always do and i get around 450 - 500 depending how i drive ... i will always use overdrive off when in normal traffic ... say anything below 80kmhr and turn it on anything over ... i will give u guys the results in say 5 days time which is the time it usually takes for me to use a whole tank.
oh another thing ... can u guys with auto gtst's tell me what rev u change gear at for each gear with overdrive off??
PLEASE PAY ATTENTION!!!
Having overdrive turned on or off will make no difference to shift points, fuel economy or power BELOW 80 kmh. If you are driving in an 80 k limit, or below, leave it off, as on and around 80 k it will be cutting in and out and will premarturely wear out clutch packs in a transmission. My O/D is always off, unless im travelling at 90 k or more....
The power buttong is the one thats will change shifts points, and the only thing that changes ratios is the torque converter because it actually can give you a 2:1 ratio in torque multiplication.....
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
