Dunlop Formula R 18" Semi Slicks
265/35/18
very good condition, ~50%.
$250pair
R32 GTR Rims Pair
16 by 8
+30 offset
very light, forged alloy.
5 by 114.3mm stud pattern (suit s14 etc)
ok condition, edge of 1 rim minor dent - see pic.
$275 pair
cheers, alex.
0409 534520
Please PM/email [email protected]
Other parts available from GARAGE-13.COM...
Click the icons for links.
RIMS/TYRE PARTS
Guard Rolling/Flaring from $40 corner...
SUSPENSION PARTS
r32 adjustable pillowball rear camber arms $249...
INTERIOR PARTS
Apexi Shift Knob $39ea...
Direct deposit, paypal, money order, pickup etc
Contact Details: please pm or email [email protected]
https://www.sau.com.au/forums/topic/88928-dunlop-formula-r-18-slicks-265-35/
  • 5 weeks later...
Are the R32 GTR wheels still for sale?
CAn you get a set of 4 and what would it cost to ship to Tassie???
bj_glover(at)hotmail.com
Cheers B
    • Starter motors used to use the weight of metal (magnets) to provide torque. Now they use (more) current instead. This. It's completely normal.
    • So thing that had me stumped, but I think is OK....is that when it was up in the air, in neutral I had it running to bleed to coolant while I put the wheels back on. I noticed the rears were turning (slowly) which I'd never seen before 20250928_163512.mp4     Because there had been an issue with clutch slip due to pedal adjustment on the dyno, I assumed there was still and issue so spent some quality time upside down under the dash adjusting the pedal....but no matter what I did the wheels still turned in neutral. Even disconnected the master cylinder to pedal rod and same. In despair, I even removed the clutch slave so there was no chance of any preload causing it.....still happened. So either: 1. Something is not right in the bellhousing, or 2. Its a thing sometimes with cold, thick gearbox oil Internet says it might be 2, I hope so!
    • OK, few more things sorted and it is ready for a shakedown on 10-Oct, with one weird thing. Changed the run in oil and filter for the good stuff. 8l came out, about 8.5 went in with filter so that looks all good. Changed the starter (again), this time for a brand new one, works good. Interesting that the Taaaarks one is shorter than factory but spins harder, I guess electronics have moved on a little in the last 30 years. Will be nice to have a bit of extra space under there. Put the timing cover back on, and noted where the cam gears were set as a record.  Will need to double check the timing but it is pretty close. Also put the coil pack cover and intake snorkel back on. Exhaust Inlet Changed the water out for coolant, bled up nicely. Removed the rear brake pads (well worn factory sumitomo ones!), gave the hardware a good clean and reassembled. I've put bendix XP on the back again because the price is excellent at $150 a set and they worked well on the V37. Front pads have plenty so no issue there
    • Mine is all -12, I’m running a dry sump in a billet block though
