there are two clips that holds the bottom in you need to use a prie bar or large thick screw driver to lift it out it does requier a lot of force. the back rest part is held in by two screws cant miss them once you have the bottom section out.
You need to use a lot of fource with the two clips I have GTR Seats in my GTST :D and they are a bugger when I first took them out I wacked my head twice on the roof because I had to use that much force it was like they where glued in
