To add a bit of variation, you can count me in.
Marc2
Awesome, 2 stagea's will keep the people guessing.
We'll have to get a spot next to each other
"why are they different, but the same?"
  • Replies 182
I think a thread was posted somewhere about this earlier, but im too lazy to go and find it  B)
Anyways, what is it you ask? Heres a run down....
So its basically a mini car show in Canberra that runs for just one day. Entry is free, and you can come and go as you please.
Anyone interested in going and representing for Nissans finest? If so ill start a list, maybe we can get 10 - 15 cars to come along?
1. Amaru
2. SkyGTRline
3. Terminal Stagea
4. mickGTR
5. Frink
6. Terminal R33
7. race_snooze
8. LTSjayce
9. leech_
10. djhatton sexy blue beast if the traitor hasnt sold it :)
11. NathR32
12. Supafly Skyline
13. ib6ub9
14. marc2
15.
I finally have the Beast Registered so i will be there :P
I could write a book on the hardships of getting the R over dickson.
  • 3 weeks later...
I've just found out i have a taekwondo tournament on that weekend. this is a shit, first i missed the show'n'shine because of a tournament, and now i'm missing this one.... such a bugger!
