I had a similar thing happen to me last weekend. I fitted a new Alpine sound system. Went to use the heater and all I got was HOT all the time.
Did a self diagnostic check on the climate control it indicated a short in the PBR. Error code was -26.
What had happenned was when I fitted the stereo I crushed a climate control wire and it shorted. After pulling out the hardware (stereo and climate control unit) I wiggled the wires a bit and put it back together. Did another dig. check and it had fixed itself. Gues the wire straightned itself out.
The diagnostic procedure is documented in the R32 manual - available on this site - somewhere.
Cheers
Bov
mine will randomly decide to blow hot air when supposed to be cold and cold air when its supposed to be hot. i replaced the unit with no luck???????? :)
ive just gotten used to having thw windows down all the time now
any ideas???????
For the R33 hold down the off button for 5 seconds (or until diagnostic mode is launched) within the first 10 seconds of starting the car then press the heat button (red triangle) once to enter the sensor check diagnostic.
wait a few seconds and a code will be displayed on the unit 20 = everything is normal
press the heat button again and it will go into door position mode (the motor that switches which vent/s air is blown) if 30 is displayed then everything is normal.
you'll have to do a search to find out what the other codes mean as i can't remember.
oh and press the auto button to exit diagnostic mode
  • 5 months later...
I've had my car for around a year now and my air con wasn't working when I got it, just needed to get it re gassed but,
As of around 4 or 5 months ago, my car has being blowing hot air down to my feet. As with Trevvy it doesn't matter what the settings are or even if the unit is on or off. :O
(I can change the fan but still receive a bit of hot air down at feet)
So I have come to terms with just pushing the recirculation button, it drops the temp by about half a degree, but on a 35+ degree day you welcome the little change for a whole 30 seconds....
Any how, I tried the self diagnostic feature 4 times, twice with only the first step (pushing the heat button once)
results as follows:
first two times: 20.
third time: 25. 3, 41, 5. :
fourth time: 20. 3, 41, 5.
My car has being in the shade for at least 3 hours and I left the doors open for a while, 5 minutes between tests. (I will try again tonight with a cooler ambient temperature, just to see what/if there’s a variation.)
So WTF??
Just to complicate things a bit further too, I've had a second after market head unit put in as well, but I have tried wiggling and manipulating the wires around but makes no diff.
Any help would be great,
Cheers,
Jules.
This happens with my R32 analogue climate control unit sometimes. I don't have a stereo in at that moment so I can just reach to the loom and wiggle it around and it will return back to normal but I have no idea what I will do once i get a stereo in there. :
Tof,
Could you do me a favour, Next time it happens could you play around and try and find which wire it is??
While yours is a analouge, Im sure the loom is the same. Just want to know if it's a particular wire or the loom it's self. On the other side of things it could be any number of particular wire(s) in the loom.
I just don't want to pull my head unit again, just yet. I've mucked around with the wires before, but it didn't make a differance. If I know wich one to manipulate at least which one works on yours then I'll give it another crack.
Cheers,
Jules
I've had a simialr problem.
In the back of the cavity where the headunit is, is a small actuator that controls a vent for hot/cold air mix. The wiring loom going into this actuator was loose or had a bad connection. By wiggling the wires it would reconnect and get the actuator working again. In your case I think the actuator may have died completely, leaving it in the hot position.
well, I say, do the diagnostic first, if any sensor showing faulty fix them first.(mostly wires connection with sensor than it self )
and check your fuses and magnet switch. if fuse is keep blowing under dash. you might have dead compressor due to drawing too much current.
I had little experiance with my R32 and end up seeing pros at unique auto down at Castle hill.
it cost $700 just recondition it because they can't find any alternative for me.
    • The other problem was one of those "oh shit we are going to die moments". Basically the high spec Q50s have a full electric steering rack, and the povo ones had a regular hydraulic rack with an electric pump.  So couple of laps into session 5 as I came into turn 2 (big run off now, happily), the dash turned into a christmas tree and the steering became super heavy and I went well off. I assumed it was a tyre failure so limped to the pits, but everything was OK. But....the master warning light was still on so I checked the DTCs and saw – C13E6 “Heat Protection”. Yes, that bloody steering rack computer sitting where the oil cooler should be has its own sensors and error logic, and decided I was using the steering wheel too much. I really appreciated the helpful information in the manual (my bold) POSSIBLE CAUSE • Continuing the overloading steering (Sports driving in the circuit etc,) “DATA MONITOR” >> “C/M TEMPERATURE”. The rise of steering force motor internal temperature caused the protection function to operate. This is not a system malfunction. INSPECTION END So, basically the electric motor in the steering rack got to 150c, and it decided to shut down without warning for my safety. Didn't feel safe. Short term I'll see if I can duct some air to that motor (the engine bay is sealed pretty tight). Long term, depending on how often this happens, I'll look into swapping the povo spec electric/hydraulic rack in. While the rack should be fine the power supply to the pump will be a pain and might be best to deal with it when I add a PDM.
    • And finally, 2 problems I really need to sort.  Firstly as Matt said the auto trans is not happy as it gets hot - I couldn't log the temps but the gauge showed 90o. On the first day I took it out back in Feb, because the coolant was getting hot I never got to any auto trans issues; but on this day by late session 3 and then really clearly in 4 and 5 as it got hotter it just would not shift up. You can hear the issue really clearly at 12:55 and 16:20 on the vid. So the good news is, literally this week Ecutek finally released tuning for the jatco 7 speed. I'll have a chat to Racebox and see what they can do electrically to keep it cooler and to get the gears, if anything. That will likely take some R&D and can only really happen on track as it never gets even warm with road use. I've also picked up some eye wateringly expensive Redline D6 ATF to try, it had the highest viscosity I could find at 100o so we will see if that helps (just waiting for some oil pan gaskets so I can change it properly). If neither of those work I need to remove the coolant/trans interwarmer and the radiator cooler and go to an external cooler....somewhere.....(goodbye washer reservoir?), and if that fails give up on this mad idea and wait for Nissan to release the manual 400R
    • So, what else.... Power. I don't know what it is making because I haven't done a post tune dyno run yet; I will when I get a chance. It was 240rwkw dead stock. Conclusion from the day....it does not need a single kw more until I sort some other stuff. It comes on so hard that I could hear the twin N1 turbos on the R32 crying, and I just can't use what it has around a tight track with the current setup. Brakes. They are perfect. Hit them hard all day and they never felt like having an issue; you can see in the video we were making ground on much lighter cars on better tyres under brakes. They are standard (red sport) calipers, standard size discs in DBA5000 2 piece, Winmax pads and Motul RBF600 fluid, all from Matty at Racebrakes Sydney. Keeping in mind the car is more powerful than my R32 and weighs 1680, he clearly knows his shit. Suspension. This is one of the first areas I need to change. It has electronically controlled dampers from factory, but everything is just way too soft for track work even on the hardest setting (it is nice when hustling on country roads though). In particular it rolls into oversteer mid corner and pitches too much under hard braking so it becomes unstable eg in the turn 1 kink I need to brake early, turn through the kink then brake again so I don't pirouette like an AE86. I need to get some decent shocks with matched springs and sway bars ASAP, even if it is just a v1 setup until I work out a proper race/rally setup later. Tyres. I am running Yoko A052 in 235/45/18 all round, because that was what I could get in approximately the right height on wheels I had in the shed (Rays/Nismo 18x8 off the old Leaf actually!). As track tyres they are pretty poor; I note GTSBoy recently posted a porker comparo video including them where they were about the same as AD09.....that is nothing like a top line track tyre. I'll start getting that sorted but realistically I should get proper sized wheels first (likely 9.5 +38 front and 11 +55 at the rear, so a custom order, and I can't rotate them like the R32), then work out what the best tyre option is. BTW on that, Targa Tas had gone to road tyres instead of semi slicks now so that is a whole other world of choices to sort. Diff. This is the other thing that urgently needs to be addressed. It left massive 1s out of the fish hook all day, even when I was trying not too (you can also hear it reving on the video, and see the RPM rising too fast compared to speed in the data). It has an open diff that Infiniti optimistically called a B-LSD for "Brake Limited Slip Diff". It does good straight line standing start 11s but it is woeful on the track. Nismo seem to make a 2 way for it.
    • Also, I logged some data from the ECU for each session (mostly oil pressures and various temps, but also speed, revs etc, can't believe I forgot accelerator position). The Ecutek data loads nicely to datazap, I got good data from sessions 2, 3 and 4: https://datazap.me/u/duncanhandleyhgeconsultingcomau/250813-wakefield-session-2?log=0&data=7 https://datazap.me/u/duncanhandleyhgeconsultingcomau/250813-wakefield-session-3?log=0&data=6 https://datazap.me/u/duncanhandleyhgeconsultingcomau/250813-wakefield-session-4?log=0&data=6 Each session is cut into 3 files but loaded together, you can change between them in the top left. As the test sessions are mostly about the car, not me, I basically start by checking the oil pressure (good, or at least consistent all day). These have an electrically controlled oil pump which targets 25psi(!) at low load and 50 at high. I'm running a much thicker oil than recommended by nissan (they said 0w20, I'm running 10w40) so its a little higher. The main thing is that it doesn't drop too far, eg in the long left hand fish hook, or under brakes so I know I'm not getting oil surge. Good start. Then Oil and Coolant temp, plus intercooler and intake temps, like this: Keeping in mind ambient was about 5o at session 2, I'd say the oil temp is good. The coolant temp as OK but a big worry for hot days (it was getting to 110 back in Feb when it was 35o) so I need to keep addressing that. The water to air intercooler is working totally backwards where we get 5o air in the intake, squish/warm it in the turbos (unknown temp) then run it through the intercoolers which are say 65o max in this case, then the result is 20o air into the engine......the day was too atypical to draw a conclusion on that I think, in the united states of freedom they do a lot of upsizing the intercooler and heat exchanger cores to get those temps down but they were OK this time. The other interesting (but not concerning) part for me was the turbo speed vs boost graph: I circled an example from the main straight. With the tune boost peaks at around 18psi but it deliberately drops to about 14psi at redline because the turbos are tiny - they choke at high revs and just create more heat than power if you run them hard all the way. But you can also see the turbo speed at the same time; it raises from about 180,000rpm to 210,000rpm which the boost falls....imagine the turbine speed if they held 18psi to redline. The wastegates are electrically controlled so there is a heap of logic about boost target, actual boost, delta etc etc but it all seems to work well
    • hahah when youtube subscribers are faster than my updates here. Yes some vid from the day is up, here:  Note that as with all track day videos it is boring watching after the bloopers at the start.  The off was a genuine surprise to me, I've literally done a thousand laps around the place and I've never had instability there; basically it rolled into oversteer, slipped, gripped and spat me out. On the way off I mowed down one of the instructor's cones and it sat there all day looking at me with accusing cone eyes as I drove past. 1:13:20 was my fastest lap, and it was in the second session, 3rd lap.  It (or me!) got slower throughout the day as it got hotter.
