use a small screwdriver to remove the 2 hose clamps, and remove. No real trick to it, you may find it easier to remove the filter from the braket to get to bottom hoseclamp
rememebr to wait for engine to cool down so you dont burn yourself on intake manifold
i just went to parts store and asked for one to fit my car.
though i might add, the stock one has a bend in one of the pipe's going into filter. the replacement they gave me, the line was straight. It worked fine, but i couldnt get the filter back in the braket
ps. check your other thread
If you go to autobarn or where ever you should be able to look the part number for a fuel filter up in the book.
The one without the bend in the pipe is for 300zx i think.
lol my names rhett 2... never met another 1..
Hey, your the 4th Rhett ive met. It took me until i was 18 to meet another person called Rhett.
What's the best way to do it without spilling fuel everywhere? As obviously when the filter is taken off the bottom clamp, and fuel in the lines is going to go everywhere? :)
I've got a spare fuel filter and have been meaning to swap it over for a while but have never gotten around to it.
What's the best way to do it without spilling fuel everywhere?  As obviously when the filter is taken off the bottom clamp, and fuel in the lines is going to go everywhere?  :P
Yank the fuel pump fuse and let the car die. Try and turn it over a couple of times and you will use up most of the remaing petrol. Have a rag to catch the rest.
I used Z 201 cost 11$ .It has straight top/out piping so You have to replaced fuel hose for longer one ,half meter 7.5 mm cost about 9 $.
Or You can use a Z 387 cost about 38$ same bended top pipe as genuine one.
Its not a problem to change I did two R 32 today .Take me few minutes .Pul out filter with smal hose from botom pipe ,than change filter out of tha car and put back filter with smal hose and top big hose already back on to botom pipe.
Fuel here is real shit so You need to replaced fuel filter at least every 10000 kms.
If You can not for same reason change fuel filter and have something to do in Brisbane ,come to my place I can changed for You.No problem.
    • I appreciate the detailed explanation, think I understand now. I spent the better part of last night reading what I could about shuffle and potential solutions. I had replaced the OEM twin turbo pipe with an alternate Y pipe that is separated further away from the turbo. The current one is from HKS and I had a previous pipe that was separated even further away, both have shuffle. I had heard that a divider can be welded in to the OEM pipe to remove turbulence, and figure that aftermarket pipes that are more separated would achieve the same thing. From what I read, most people with -10 turbos get shuffle due to their size, though it's a bit less common with -5s on a standard RB26. I think Nismoid mentioned somewhere it's because OEM recirculation piping is common in Australia with -5 cars. It seems that the recommendation tends to vary between a few options, which I've ordered in what I think is most feasible for me:  1. Retune the MAP or boost controller to try to eliminate shuffle 2. Install OEM recirculation piping 3. Something called a 'balance pipe' welded onto the exhaust manifolds. I don't know if kits for this are available, seems like pure fabrication work 4. simply go single turbo My current layout is as follows: Garrett 2860 -5s HKS Racing Suction intake MAF delete pipes HKS racing chamber intake piping hard intercooler piping,  ARC intercooler HKS SSQV BOV and pipe Haltech 2500 elite ECU and boost solenoid/controller HPI dump pipes OEM exhaust manifolds HKS VCAM step 1 and supporting head modifications Built 2.6 bottom end All OEM recirculation piping was removed, relevant areas sealed off I'll keep an eye out for any alternative solutions but can get started with this.  Only other question is, does shuffle harm the turbo (or anything else)? It seems like some people say your turbo shafts will explode because of the opposing forces after a while and others say they just live with it and adjust their pedal foot accordingly.
    • That worked out PERFECTLY! Thank you big time to JJ. He was able to swap me his stock diff. He drove all the way to me as well. Killer! Removal & install was pretty straightforward. The diff itself is HEAVY. So that’s a 2 man job.  Man does the car drive nice now! Couldn’t have worked out any better 👌
    • I'm interested,do you still have it?
