It's not heaps... just a very very fine coat of soot ~ doesn't piss me off about the richness since I'm now getting about 400+ per tank afte SAFCII, just pisses me off that i have to clean the rear bar each time :(
bitch bitch bitch... try having VTEC and a Honda ECU dude... VTEC = puff of brown smoke at ~5250RPM... my bar is ALWAYS sooty! :D
Honda ECU... you add any mods - it keeps the a/f the same! CAI... Exhaust... to make it run a bit leaner/more efficient - etc... it'll change it back to stock a/f ratio! ;)
  • Replies 625
Posted Images
Did I mention it backfires constantly when I go off the throttle and it's been spooling hard.. not good ;) think it's excess fuel just getting dumped into the dump-pipe which ignites instantly.. sounds like someones making pop-corn just under my feet..
have the same thing
Thank you liz.. you just put my mind quite at ease.. it's not good is it.. just give it a bit of throttle and it's happy.. I think it's because it kills ignition but doesn't stop fuel getting dumped in.. than it hits the turbo dump pipe and VOOMPH! it's pops..
john ...sorry...my cb didnt go far eunf.....dacow in the integer was ahead of us and he call me to warm about the copper.....so i mention is on the cd..but i think only some can hear me
your cb wouldnt have worked that good, considering i dont have one. lol
i think ill invest in one next cruise
When using the CB you have to make sure you don't have code sequencing on - it usually appears as a second little number next to the channel..
What this does is it only lets you receive from people with the same code.. which means you won't hear anyone on the general channel..
just a piece of quick info..
If I recall he was in a very pimped out looking R34 4-door that my friend and I both commented on - man that thing sat sooo well on the road when we were cruising along behind you..
What suspension setup does it have..
i think i was between u and that wigga mobile for a bit... that thing didnt roll at all!!! i was all over the shop and he was just crusing along.. another photogropher that i was near ;)
loving the pics from everyone.... maybe there should be a SAU pic competition :D
man i think i respray my car...i am starting to get a headache now!!!!!  everywhere is yellow!!!!!!!!!!!!arggggggggggg
Yeah, I was going to go Yellow, but I have started to see it everywhere..
Ill keep it black for a little while :D
lol..
I think that was me.. also managed to kill the spider that was climbing on your from one shoulder to the other before we left..
hope you had a good day enjoying getting driven around rather than you driving all day..
That damn water at maccas, was bloody room temperature so we spent the day hunting down cold water..
your car looked nice.. made a couple of pics in the carpark :D ..
Edited by Links
Sorry silver about not being able to warn you earlier.. I didn't have anyones numbers except for mintie's! I thought you guys were in one group and would have heard :D
:D
lol..
OMG~~the spider thing was u as well?can not believe u saved me twice on the same day!!!(from the spider & thirsty~~~)lol
yeah my car will looked better after i fix the dent
what i mean before is that on the way back when we were all turning right to 'newcastle / scenic route' i went sttriaght ahead.. so tthen i took the 1st turn off and then went the other way (kamakasi style) then turned around when i saw yas all :D
also pm link video .. im dude in yellow r34 for those who are wondering
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
    • I also used NP   That’s were it’s seems to be the best place to fit it? All schematic shows also that it’s should be referenced from the turbo housing. But idk, I do see high hp cars without any connection or anything to their turbos, so I really don’t know how they connect their things
