PICS ADDED BELOW
Item: Genuine R32 GTR Brake Booster
Item Condition: Works Perfectly No Leaks etc.
Reason for Selling: Brought after being told mine was stuffed, but alas, it was the master cylinder (bastard mecanics)
Price and Payment Conditions: $150 + Freight ono
Extra Info:
Contact Details: Ben 0409 910 960
Also have the following.
Standard IC from s15, good upgrade for most nissans made before 99.
$80
Pics can be provided just PM me or call me on 0409 910 960
Cheers
Edited by DRAGTS
Sorry to take so long to reply. But yes i beleive it is a goor little upgrade due to the thickness of s15 cooler. Will do some pics 2morrow[
quote=daler32,23 Oct 2005, 09:51 PM]
u got any pics of the s15 cooler? and is it much of an upgrade for an s13?
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
