G'day Ed,
I'd say they could book you the same as they book people for using mobile phones.
But I think it's fine to have it on and on the seat next to you. They would have to catch you actually talking into it.
I used to be a big CB user years ago, and the cops never worried about it then, but ahhhh how times have changed.. LOL
J
https://www.sau.com.au/forums/topic/9046-handheld-cbs/#findComment-134690
AFAIK the use of 2 way radios whilst driving is not an offence in itself, whether they be handheld or fixed with mic. If your driving ability suffers greatly whilst using the handheld then I'm sure a policeman who observes this could do you for reckless driving or some such offence.
I have seen the relevant regulations (in Victoria I think) posted in four wheel drive forums previously.
https://www.sau.com.au/forums/topic/9046-handheld-cbs/#findComment-134708
well, I just found this on the RTA website...
Taken from http://www.rta.nsw.gov.au/rulesregulations...ads/pts1-21.pdf (page 310)
300 Use of hand-held mobile phones
    (1)  The driver of a vehicle (except an emergency vehicle or police vehicle) must not use a hand-held mobile phone while the vehicle is moving, or is stationary but not parked, unless the driver is exempt from this rule under another law of this jurisdiction.
Offence provision.
Note Emergency vehicle, park and police vehicle are defined in the
dictionary.
    (2)  In this rule:
            mobile phone does not include a CB radio or any other two-way radio.
Looks like we are safe :shake:
https://www.sau.com.au/forums/topic/9046-handheld-cbs/#findComment-134748
Handhelds rock, specially for pointing out that chick on the corner at the lights just to make sure the lads behind you get a look ;)
But I do think they severly impede your ability to kick the pants off an R34 when you miss 2nd because your trying to taunt Franky and then rem you have to change gears :P
Franky will prolly tell you that his incident was mainly because he was talkin to that mermaid on a handheld CB :bahaha:
https://www.sau.com.au/forums/topic/9046-handheld-cbs/#findComment-135433
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
