I have 2 gauges for sale, both are electronic and have memory functions such as peak hold and setable warning indicators
These are not the inferior mechanical gauges with mo memory function...
All wires supplied for the boost gauge.
The temp gauge can be used for oil or water, but a new temp sensor is required (the plug like thing at the end of the wire) as mine was welded to the oil sump plug and unable to be removed
http://www.nissansilvia.com/forums/index.p...e=post&id=17354
http://www.nissansilvia.com/forums/index.p...e=post&id=17358
I had both gauges mounted on a faceplate which i had discretely placed in my S15 glovebox, no hassles from the boys in blue...
The Greddy key for setting the warning is also included
http://www.nissansilvia.com/forums/index.p...e=post&id=17357
Here are links for specs etc:
http://www.eautoworks.com/ORD-Auto~perform...uges-no-930.htm
http://www.eautoworks.com/ORD-Auto~perform...uges-no-933.htm
$350 firm for both gauges and i will also throw in the faceplate
$25 for P&H interstate
pick up or inspection is welcome in Melbourne
#price reduced#
Now $300...
PM or email to [email protected]
Edited by R1Titan
https://www.sau.com.au/forums/topic/90621-fs-greddy-electronic-gauges/
