Hi, I am confused. My r32 gtr has the restictor olives removed when I bought the car. They came to me in a plastic bag.
I know one goes in the hose with the yellow band fitted to the boost controller, but where the hell does the second one go. I have two olives in the bag. I have never heard any mention of a second one. Most guys simply remove the one near the boost controller and get 1 Bar boost. My gtr is making slightly more than 1 Bar and getting boost creep high in the rev range with standard ceramic turbos! Not good.
Can anyone tell me where the other olive goes. I want to try and refit it and see if that drops the boost a bit.
Thanks
https://www.sau.com.au/forums/topic/91184-boost-restrictor-on-std-gtr/
yeah the other restrictor goes on a hose at bottom of plenum right at the back really difficult to get too. The hose runs off plenum and goes down and joins back onto hard piping joined to block there should be a yellow band still around hose
hope this helps & good luck
Thanks for the info. I had a look last night, that hose in imposible to get to.
The funny thing is, I can feel a buldge in the pipe at the plenum end. It's hard if I squeze on the pipe, so I think it is still in place. Are there any more restrictors in the boostlines? I have two olives spare so they must have come from somewhere. They were removed when a Powerchip was installed.
I know a guy who has a complete gtr engine currently sitting on a pallet in his garage. I will take a close look on Monday.
  • 4 months later...
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
    • So, now all you need to do is connect the 2 or 3x 12v feeds into the unit to permanent 12v, ACC 12V and IGN 12V that you can find in the spot behind the stereo, and the earth, and then it will switch on with the car.
