Guys,
Ive posted before asking if my setup will make 350AWKW, know id like to know the following:
Will the facotry ignition system keep up?
What spark plugs and what gaps?
Will the R33 GTR pump keep up?
What gearbox Oil?
What Front Diff Oil?
What Rear Diff Oil?
To refresh your memmory my setup is
RB26 Head Mildl Ported and Fully Rebuilt
HKS Step 1 272 Cams
HKS Cam Gears
Nismo 600cc Injectors
Apexi Power FC
Nissan Q45 AFM
R33 GTR Fuel Pump
Nismo Adj. Fuel Reg
GCG XTR T60 Turbo
GCG XTR 55mm Wastegate
Custom Manifold (Equal Length)
100mm Thick Cooler
14-Row Oil Cooler
RB30 Bottom End
O-Ringed Block
Head Restrictor Etc
H-Beam Conrods
CP Forged Pistons
ACL Race Series Bearings (Heat Treated Ones)
Straigh Through Exhaust System
Twin Plate Clutch
All this is going into my R32 GTR with a standard R33 GTR box. I dont think ive missed anything let me know if i have
Cheers
Edited by GTR_Junkie
https://www.sau.com.au/forums/topic/91191-some-questions-about-my-new-setup/
sounds good.
redline oil heavy(red one) in gearbox and diffs.
coils shouldnt be a problem but you may need to gap the plugs down
id use a iq22 denso.(7 range in ngk,0.4mm iridum.)
fuel pump wont cut it.
injectors will be at there max.
youl need a much biger oil cooler
stock pumps are at there limit around 370-390rwhp.
just put in a bosch 044(rated at about 600-700hp) i think.
go easy on the stock box as 3rd gear is weak as shit, not fun to change believe me.
Injectors at there  max ???? and a bigger oil cooler??? Maybe i should have stated it will be street driven not track raced or anything
Thats not what u said in ur other threads on the same subject.
A 350rwkw GTR is a waste of time and fuel driving as a daily driver on the road these days.
330rwkw 600cc injectors at 90% in my old motor.
oil temp with properly ducted 25row oil cooler still gets up to 115deg from brooklen to berowa. about 5mins flat out.(sock 32gtr)
id run a external 044 with a surge tank etc(unless you always have a 1/4 tank)
if you are going to do it you may as well do it properly.
    • I've seen similar actually in my situation. You never know what tables are attempted to be used when the car thinks it's -99C or +200C. The fail state is not usually that extreme but you know what I mean - it was in my case though! This is where being able to read all the sensors is useful cause you see this stuff really quickly.
    • The above is very important. However as long as you keep timing relatively low, it's plausible to make your own knock ears and plausible to learn to tune with a modern ECU that can do wideband O2 correction like a boost controller. I mean if you only have one viable road to even drive the car on, learning to tinker to this level may be worth doing given you can't do much else with the car...?
    • I find the fact that the rear plate has to be bent inwards at the rear not so bad: but the front is just awful: It's like come on. (these are my very old, now retired/turned in plates) TBH it is a lot of money to fix a minor issue, the fact I said "I'll never really spend the money on doing this" is why people ended up buying them as a gift for a 'car guy' who can be hard to shop for.. for car guy things.
    • I just bent the ends of my premo plates. It even went through Regency like that after the engine conversion and the inspector (a great bloke!) just squinted his eyes and said "I didn't see that". Plates, and how they look, are just something that have zero importance to me.
    • Yeah, I would have said the same. It makes me suggest that there are other things wrong, such that the ECU is totally unhappy with the broken sensor. The only other thought here is that maybe it is shorted, which might cause a different issue to the typical "disconnected" sensor.
