Hi everyone, anyone inerested in a clean R32 GTS4 93.
Imported 3 years ago from a nissan mechanic over in japan,
have done minumal k's and has benn very well looked after.
It is pretty much well stock apart from a few modifications.
Bilstein suspension all round.
Cusco front strut brace
New Rotors all round.
3" Turbo smart cat back system.
Turbo smart BOV and boost valve.
Cold air pod and gaurd.
Alarm.
Tinted windows.
Pioneer head and six stacker in rear.
The car has 176,000 k's but is in great condition. Only put on 20k since bought from japan. Every mechanic I take it to says it is one of the cleanest, quiet and smooth car with the amount of k's.
Urgent sale buying a house and need the money.
Very sad to part with this baby GTR. After 13k.
If interested please email me on [email protected]
post-24073-1130037675.jpgpost-24073-1130037756.jpgpost-24073-1130037808.jpgpost-24073-1130037851.jpgpost-24073-1130037886.jpg
Edited by cusco
https://www.sau.com.au/forums/topic/92120-r32-gts4-on-the-market/
Alarm.
Tinted windows.
bump
Alarm.
Tinted windows.
you negotiable on price?
    • Resizing injectors in Nistune can be done a couple of ways, and there are a couple of ways that you can make a mess of it. The tuner needs to be really aware of the effects of whichever approach he uses (either K, or TIM). They are both easy enough to "get the injector size right" to run the engine. But little details like old start enrichment and hot start are affected differently, depending on which boxes you check.
    • Pretty safe to say almost everyone that has tuned their own car has experienced this issue. The difference being that we have our laptop in the car and when it happens, it's literally 10 seconds of tuning to sort it.  Would you be happy to plug in your laptop and sort this yourself? It is a very simple process and there is no risk of harming your engine (if you are worried about that).
    • Yeah thats the next step now, either they wil or i will take out for a drive to work and go straight their after work and see is we get the same issues 🤞  thought i try my luck here too, never know someone else might have had the same issue but thanks for the reply
    • Basically your tuner needs to drive it for the 30 min (or whatever) to create the same conditions then check the ECU settings and sensors at that time. They may not be excited to because that takes them 30 min rather than just opening the bonnet and seeing the problem straight away.... Hot start is generally not as tricky as cold start, but there would be a table for fuel enrichment vs coolant temp as a starting point
    • Yeah, they all cant say anything for sure as everything is working fine . Said unable to find an issue untill it stops again. Could mist likely be CAS wiring or IAS valve issue but again not 100%
