You hear an echo..........
Running rich because of the BOV.
I'd say your original one is a plump back version were this new one vent to atmo.
Your air flow meter already has sensed the air go in so it provides the fuel for that amount of air. When the air gets vented out and not back in....too much fuel and that's when you get the popping.
Even if you place the silcer back in and don't hear it, it is happening, running rich that is. Not a huge issue as it only happening at the time its venting out unless you have an air leak now from the BOV or the BOV is not sealing properly.
You'll have to check this out.
https://www.sau.com.au/forums/topic/92166-backfire/#findComment-1661640
I have a R34 GTT with a HKS SSQV on it & it does the same thing, it never use to before i put the bov on. Its nothing to worry about.  :P
Does this only occur on the first 10-20mins of driving though. Thats what happens to mine then it dissapears.
https://www.sau.com.au/forums/topic/92166-backfire/#findComment-1661886
do you have a hard and soft setting on the blow off valve?
if it is, let it idle and give it a blip, if it goes back to normal idle speed i wouldnt worry about it
if it goes below normal idle speed, ya keep turnin it hard till it stops .
it wouldnt hurt gettin someone to have a look at it too , just so you know for sure theres nuthin sus about it.
THanks
Barret
https://www.sau.com.au/forums/topic/92166-backfire/#findComment-1679396
THanks
Barret
the noise seems to have gone away
i have loosened the spring though..so it is on soft
https://www.sau.com.au/forums/topic/92166-backfire/#findComment-1679436
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
