Hey guys,
i have a small problem at the moment with my cars fuel eating habits. ever since ive had the new upgrades, i would be lucky to get say about 220kms from a full tank......
i have noticed that it spits out a little black smoke when you give it a hit as in high in the rev range, but i just figured it is running a little rich. there is also a petrol smell, also it back fires a lot more.....
ok im just wondering peoples thoughts on this, and if i should invest in another tune, any ideas on how much a small and simple tune like that would cost????
cheers
Mass
https://www.sau.com.au/forums/topic/92273-bad-fuel-economy/
  • Replies 40
yeh i figured that it maybe things like that, but the thing is i have a new o2 sensor, new fuel reg, and i just had it tuned, thats why i was thinking its prob the tune...
the reason for this thread is i was after some thoughts/comments from those who have similar mods to me, and how their fuel economy is, in other words what i should be expecting..
https://www.sau.com.au/forums/topic/92273-bad-fuel-economy/#findComment-1663683
Better fuel economy then what your getting!!!
If its recently been tuned maybe speak to the tuner and get them to check it out. Backfiring, popping & black smoke are all tell tail sign of it running rich. There might be other factors to consider - did this suddenly happen or was this straight after your tune.
Something like your O2 Sensor, Airflow meter, Fuel Reg, vacuum leak, clogged injectors could be having an effect.
If straight after your tune - speak with them as a re-tune is needed or the fault has to be found before this can be sorted.
https://www.sau.com.au/forums/topic/92273-bad-fuel-economy/#findComment-1663712
yeh it was after the tune.. i can eliminate all those factors, as i have all the following new:
Air Flow Meter, 550cc injectors, Fuel Reg, o2 sensor, and new vacuum lines....
i think i have to speak to the tuner, it does pop and crackle a lot...
https://www.sau.com.au/forums/topic/92273-bad-fuel-economy/#findComment-1663718
You might have 250rwkw but this dosen't mean you should have bad economy.
If everything is working, correct installation, a good tune and good driver behaviour your fuel economy should be good, I believe 400+ km at least, some people I'm sure are getting alot more or a bit less.
https://www.sau.com.au/forums/topic/92273-bad-fuel-economy/#findComment-1663755
Take it back to where you got it tuned.
Give them the chance to help you, hopefully its a simple problem and they might be more then happy to help. I might be too optimistic but I hope they don't want one of the cars they have tuned runing like that.
If not, then you can cross that bridge when it comes but I'm sure there are some reputable tuners that will get it right.
Your car runs as good as the tuner that tunes it!!
https://www.sau.com.au/forums/topic/92273-bad-fuel-economy/#findComment-1663789
put a full tank in and dont hit it once :D
like, really concentrate or let your mrs/mum drive it for a week and see what they get.
For ages i could neve get over 300, stuck the mrs (at the time) in the car... 440 right off the first tank. Ive never beaten it yet!
https://www.sau.com.au/forums/topic/92273-bad-fuel-economy/#findComment-1664168
    • Yes I can see how that would put you off HFM, especially with the price of good quality brake fluid. From what I understand it as you say the BM50 is the standard BMC for a R32 GTR, I must admit I would like to go far a Genuine Nissan BM57, but lack of cash prevents that at present. With the price being so close between the genuine BM50 and BM57 a BM57 New it seems a better choice as you gain that 1/16 bore size with the BM57, I would be interested in how much difference you feel with the BM57 fitted. I am going to take SteveL's advice in the short term and see how much actually comes out of that proportioning valve vent and save up for the Genuine Nissan part. Thanks for clarifying the HFM failure
    • Thanks mate. I just got the post inspection 1/2 done from state roads when the starter motor packed up, either that or the car alarm system is having trouble.  OEM part number 23300-AA112.
    • Hi, I though I was coming to an end in finding a replacement starter motor for a rb25de neo. I came across a starter motor from Taarks and a message below stating: Direct fit. 11 Tooth count. All below part numbers have been superseded to 11 teeth. Can some body shed some light on going from 8 teeth to 11 teeth apart from 36-month / 25,000 km warranty for passenger vehicles to 12 Month Warranty. Compatible with the following Nissan part numbers: 23300-20P00 23300-20P01 23300-20P05 23300-20P10 23300-20P11 23300-AA111 23300-AA112 23300-AA300 23300-08U10 23300-08U11 23300-08U15
    • Low battery? Maybe check capacity? I know first-hand, on BMWs if your battery drops below 80% capacity, it starts causing strange issues.
    • 8.5 +37 = should fit rear, but I think it'll hit on front. What you want is low 30s/high 20's front, mid 30's rear. That 17" screenshot you posted looks good, I'd run it on my R32 (but that's long dead now). For tyre sizes, my rule of thumb is: 8': 235, 9": 255. But that's just my opinion. Nismo sizes: 18x8.5+35/18x9.5+38 is a good starting point.
