ok, i have r32 gtst type m rb20 and i have a greddy type s bov in place of the stock one, it has the plumback running back to in behind the afm to the turbo, i took that off and let it vent to atmosphere and blocked off the plumback line should this be ok ? i know its illegal to vent to atmosphere but f*k i love the sound so much i cant help it, i know if i dont block off the plumback the car will stall + its letting unfiltered air through to the turbo,
i think i just need the whole process explained like the air that would normally be plumbed back if i had it connected comes in after the afm and as such isnt measured so i dont see why it would make any diff to block it off.
somebody please explain this to me :)
thanks ;)
https://www.sau.com.au/forums/topic/92324-bovplumback-question-~/
Hey Deanzzz, i know for a fact in the R33's and safe to say in the R32's too that the ECU uses the plum back pressure to regulate a/f ratio... now when the BOV vents the pressure into the atmosphere the ECU goes nuts causing an imbalance in air/fuel ratio hence stalling... the safest and best way is to use an adjustable plum back BOV such as the GFB Stealth.. these can be adjusted to how much pressure is atmospherically vented and how much is plummed back.. unless you change the ECU and update the AFM to a map sensor, ur greddy BOV will continue to give you the same problem! personally i think the standard BOV is the best upto 12psi - 14psi.. if you want sound.. a stock BOV + POD filter + FMIC will make enough noise to turn heads!!! Just a thought.... but if u really want that loud Ptssshhhh... get a GFB Stealth...
Regards,
Sarkis
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
    • You haven't driven many modern cars then have you? Most of them have sfa steering feel with their stupid electric bullshit steering systems.
