Has anyone in QLD insured their Stagea ? and with whom, Suncorp dont mention the Stagea on website.
My sisters stagea is insured through Just Car Insurance. I think she would have tried Suncorp first but not sure. I'll ask her in the next couple of days.
Cheers
I shopped around with my stagea and decided on Unique Car Insurance, was several hundred dollar's cheaper than my r33 was with suncorp, which is surprising when I listed the mod list, which was a lot longer than the r33 ever was.
http://www.uniquecar.com.au/
I opted for the $14 extra for the windscreen cover and already had it replaced with no charge. I have been very happy with Unique, thier customer service is excellent.
They also are a member here on SAu and offer members discounts, how much I wouldnt have a clue.
SKA,
How much was your policy?
I still thinking about buy a Stagea and would like to know
My R33 gtst is thru Suncorp approx $700 a year full comp.
But it is stock...
I know Suncorp is trying to stay away from imports, but if you have other insurance policies, they will normally cover you
I have 3 cars, a house and boat thru them.
Just spoke to Suncorp with no luck
They have never insured a Stagea before and will not
The phone chick went and asked the insurance underwriters while I was on the phone
They had no details about Stagea's, so I told them approx $24k for a series 2 when she asked
Their reason for not considering it was it would be to costly to get parts
hey ska you from brissy
if so you going on the club empier cruise on this weekend
No I am going on the bribie island cruise:
http://www.skylinesaustralia.com/forums/in...showtopic=89445
BUT emmanuel is going to the club empire cruise, he is in a gunmetal grey S1 Stagea, check out his and my ride here in the stagea section:
http://www.skylinesaustralia.com/forums/in...showtopic=89991
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
