ok I have 4 of these 5x114.3 bolt on wheel spacers for sale, they are a whopping 30mm thick with a 1.5 thread, but can be used with any thread as they come with wheelnuts. They are also brand spanking new billet aluminium. I dropped one of these from one foot high onto my garage floor and It rang so loud I almost went deaf.
There is a problem tho, The hubcentric ring is too big diameter wise, I could not get any of my wheels to fit, I do not know if this is because they were not meant for nissan, or weather it is a manufacturing mistake.
so only enquire if you are willing to take the time to grind the hub ring off or make it smaller, or even take them to a machinist to be done.
hence I am selling these for $30 each. ($120 for all four)
PICK UP SYDNEY ONLY
PM me if interested.
Edited by midnight
https://www.sau.com.au/forums/topic/92615-30mm-5stud-spacers/
nah sorry. I only posted em for sale today so Im fairly set on $120.
I dont really want to post as all 4 of these are quite heavy and I'm loosing money on these as it is.
They are cheap because the hub ring will need to be ground off or made smaller.
I originally bought these from wheelworx in SA for $65 each + $20 for freight.
But they did not offer refund when I told them about the issue,
so Im just trying to make abit of the money back.
    • Got the passenger door on plus the master cylinder and booster. Loaded up to take it home. At home, the colour changes a lot in the light.
    • Nothing cheap, but I have seen the AC Hydraulic DK13HLQ which is pretty close to what you're asking for. The problem is the hydraulic cylinder mandates that the back of the jack be a certain height and Skylines have fairly deep inset floor jack points. A more certain and cheap option is to get some nominal 2x10 inch lumber boards and have one board be 1.5 feet, the other board 3 feet. Glue it all together with lots of clamps to maintain pressure. Make two of these. The ramp suggested above is a good idea, it takes quite a bit of clutch slip to get over each of the boards. I only need the first ~1.5 inches for my low profile jack on a standard ride height car but a lowered car you want to go up to the full ~3-3.5 inches. Paint it or store indoors if you want it to last.
    • Ok. And Nistune? I read (here too) mainly on Stagea threads that it can by "turn off" with Nistune. But they say they still had the sensor plug in. Next week iam going to the Nistune(and other ECUs) tuner so i can finally make it work. I drove the car home and apart from the cut it drove great. No misfire no smoke no hesitation or rough start...so hoping it is this sensor that is missing
    • I just stack 2 pieces of 200x50 timber on top of each other. Total length about 900mm, with the top one being a little shorter and both having a 45° angle cut on them to make the front edge a bit of a ramp. Put these in front of each front wheel, drive up on them, throw the trolley jack under. Takes 1 minute. Scissor jacks can eat a bowl of dicks. I never use on under my car unless desperate.
    • Well, yeah. But I just expect everything other than my car to feel like a bucket of shit anyway. I still miss my Alfa 116 so much though. You could run over a 20c piece and tell whether it was heads or tails.
