  • Replies 178
Hey.. What a spin out!! The owner of Lazerzone just called me at work enquiring about web hosting for a lazerzone web site!!
HAHA... I assumed that one of you guys had called there or something, but he had no idea about any SAU forums etc.
I haven't heard from this guy for yonks and as soon as we start talking about his business, he calls me.... :headspin:
he has never called me before just to put it in perspective...
Oh.. and yeah he said that he could do us a good deal for a group and because of ME :P
We threw around the date of 15th Feb. That gives a few weeks to prepare and get the word out etc.
What do you guys think? Lazerzone Penrith?
We can have the place from 9pm-12am on 15th Feb providing we have approx. 20 people. Cost is $15 each. Quite a bargain considering its usually about $8 for a single game.
There's 10 a side, so we should be able to get about 7 or 8 games if you want to go hard, but you'll probably get a bit bored after 4 or 5. As benm said, there's other things to do around Penrith in between games etc. :headbang:
I need to let him know pretty soon if we wanna do it and whether we have the numbers. Feel free to PM me if you're in or want any more info..
Originally posted by Silver-Arrowz
Does it have to be 15? Got track day next day and don't want to wear myself out. Weekend after.
Nup. doesn't have to be, but just think, you have to play 2 games and you're already ahead. It's not that tiring. I played a couple of 'Midnight 'till dawns' pretty much playing for 5 or so hours straight...
Don't think there'll be a problem just playing and paying for a single game though...
Up to you guys, but spread the word and let me know soonish so i can book it.
BTW: there doesn't have to be 20... more or less is fine... :D
Originally posted by benm
Their are 2 clubs within 30m walk and 5 clubs within 300m walk.
hahaha
Penrith clubs are shocking!!!!
they will never come to penrith again ben :)
but yeah would be nice to show the bogans out here what some real cars are..
hey 50$ kebabs are only 200m away from laser zone :)
Dammit, everytime I've wanted to come to a TW meet, I've had something else planned or something come up to stop me from getting there - it's like 4 weeks in a row now, too!
This weekend is no different, got an engagement to attend.
So much to do, so little time...
    • Guys since i bought r33 gts25t coupe 1994 automatic a/t(manual swap 350z gearbox)  all i got is problems, always problems. Lets start with that when i turn key into ignition(ON) fuel pump doesnt always works. Sometimes i have to turn key twice Off/on/off/on until it primes. Its new, dw300 - 340lph. My gearbox broke so i did gearbox swap, install different intake manifold, injectors and i take pipes. Car was sitting in garage for more than half a year. I did assembly all not that long ago and when i turn ignition cant hear prime. All of sudden it stopped working. Theres many videos on YouTube how to make relay mod on r33 straight from battery so i did and it doesnt work! 😰 30 - battery positive  87 - positive from fuel pump to relay 85, 86 - one of two wires from original fuel pump wires(light blue, grey) and it didn’t work. so I check on ignition and took original BLUE relays wires from trunk, next to fuses. (I believe it’s IGN+ and ECU pin 18. it didn’t work…  tried connecting (IGN+ from og relay) and (ECU 104 from 1of4 FPCM wires) to my new relay 85/86 and it didn’t work.  I unplug FPCM. Didn’t work. im thinking what’s wrong   fuel pump is working, if I leave IGN+ on 85 and 86 straight to ground it works but it’s just nonstop. Since it getting constant 12v after key in ON. light blue wire gives me 6-8v.  so how this should be connected? What causing ECU not giving — on pin? Or I did sth wrong and that’s why it doesn’t work? I need negative signal on ECU that control fuel pump. What this should be?
    • You can use your VIN to look up the factory part number somewhere like amayama, and then look to order new if necessary. https://www.amayama.com/en/genuine-catalogs/nissan Depending on price you might want to rebuild instead. @GTSBoy I had an interesting insight into US market parts when the Titan rear calipers were sticking. New calipers were dirt cheap, about 20% more than a rebuild kit....they are just considered throw away maintenance items
    • Funny, but really not funny. Thank god (most) f the world has moved on since then
    • Lots of votes for driving onto a plank first; that is the quickest way I've found, 25mm is enough for my case but that will vary by car It also depends where you are going for. On the 32 I can get to the rear diff with my floor jack if I do that end first, and get it up on stands. Then I lift the front from either front tow hook as high as needed, also onto stands. Sometimes I need a small lift on the other tow hook to get it level enough If I do the front first I can't get to the rear diff because of the angle of the car Other options are getting to the front mount of the rear subframe from in front of the wheel (if only lifting one side, or just do both which is a bit of a pain compared to one lift from the diff), or also the gearbox cross member mount on the driver's side if you are  just trying to lift the driver's side. I This is the jack I use; it says 75mm clearance but of course that is only on the lower section so if you have to reach too far in like the diff you still get stuck. https://www.snapon-bluepoint.com.sg/category/Floor-Jacks/product/Floor-Jack,-2-Ton-Low-Profile
    • On the bright side, the weather will turn much nicer for working outside shortly....sounds like you might need to start on a neighbour's garden next
