As it says guys if we want to be dickheads lets do it here.
http://www.wsid.com.au/MajorEvent.asp?Even...age=Information
Please post intrest as Leech thinks hes going to whip my arss (more then likely will)
No slicks Lee. I still dont have a camber kit either.
This has been brought up due to ppl winging about friday nights events. SO lets get a group and go race.
https://www.sau.com.au/forums/topic/92684-wsid/
lol i never said i would win i actually said i would loose but i want to see by how much :( just out of interest whats the go in terms of how early you have to be their for a checkin type thing eg could i drive up after work eg 4pm or something have a couple of runs then drive home ???
https://www.sau.com.au/forums/topic/92684-wsid/#findComment-1671979
i'm not going to bother, my car isn't a sports car and i don't drive it like one :D would be good to watch though, but wsid is a bit far on a friday night.
i think its only on wednesdays anyway and as if not take the stag up awd + rb25det would be great not sure how heavy those beasts are though
well maybe we look to get a bunch of us up early jan ???
https://www.sau.com.au/forums/topic/92684-wsid/#findComment-1672512
i'm not going to bother, my car isn't a sports car and i don't drive it like one :) would be good to watch though, but wsid is a bit far on a friday night.
Sports car?
You don't need a sports car for WSID... any car can go flat stick down a straight line :D
https://www.sau.com.au/forums/topic/92684-wsid/#findComment-1672648
it's not the awd and rb25det, it's the auto + 1800kg with fuel/driver that makes it slow. i'm going to keep this wagon in good condition, then when i get the Autech, i'll take it on a track (RB26DETT + 5spd awd wagon)
https://www.sau.com.au/forums/topic/92684-wsid/#findComment-1672793
SOFTTTTTTTTTTTTTTTTTTTTTTTT it seemed to keep up fine on friday
https://www.sau.com.au/forums/topic/92684-wsid/#findComment-1672938
Autech? MMMmmmm...260RS=yummo! When's this changeover gonna happen,Termi'?
https://www.sau.com.au/forums/topic/92684-wsid/#findComment-1675403
this sounds awesome.......
however, i do think if it is to be organised, it should be done for some time in the new year. its a wednesday night, some ppl need to get the time off work and this gives us plenty of time to organise one.......
https://www.sau.com.au/forums/topic/92684-wsid/#findComment-1676261
ok so the general consences is to have this after the new year, ok sounds good to me i was hopping sooner but hey there is already plenty of things coming up soon, like formals and Cars in the park on THE 20th OF NOVEMBER
Edited by race_snooze
https://www.sau.com.au/forums/topic/92684-wsid/#findComment-1676689
    • A bit late but A disk S13P fit over stock R32 GTR brakes, usually A disk front, O disk rear works.
    • Or, the height of the release bearing is not correct for your combo. Start with the bleeding and checking the slave moves throughout its range when you press the pedal (2 person required), but it is possible for the height to be internally wrong too (box back off to measure.
    • Yes, there's quite a few things that can go wrong during a clutch install. Very unlikely. I have a similar clutch. They (ACS) make good gear. No, it is not normal. It is possible that you just need to bleed the clutch slave. But the new clutch will also have a more aggressive actuation force/pressure, and so your old slave cylinder might be a bit leaky or otherwise compromised, and not up to the extra force required. Or the master cylinder, same.
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
