  • Replies 139
Posted Images
fun times Mud...
looks like i lunched my engine on the way to work this morning....
something (i don't know what) appears to have gone through my compressor blades, which in turn has spat bits of metal through the intake, and possibly (most likely, seeing as i found lots of it around the throttle body) into the engine itself...
pulled a spark plug and i can see shiny flakes sitting on top of the pistons...
ah, so much fun!
fun times Mud...
ah, so much fun!
I'll come to you,
We can push it out in the driveway/ road to take pics.
You can't get out of it that easily!
Dave, I have Wednesday 1pm - 3pm openif your not fdoing nything, otherwise tonight or Wednesday night?
James Wednesday night is a goer, where you wanna meet, which side of town are you on?
Jason, PM me you address, I'l be around tonight to do your car.
I'll wash the car tonite then. What time were you thinking?
If you can get to shell Nudgee tonight at 8:30 I can do you and James?
LoL, I'll be bloody going for it hey. Car is caked in mud from yesterdays storms.
But which one is that? The one off the gateway? I dont know northside at all.
