Bwaaaaaaahahahahahahaha|!!!!
  • Replies 53
Originally posted by darK
why did the NSW people post this thread in victoria...
its just putting up our post count...
pssssssst...
We don't really care about the post counts. We were just having a bit of fun because of that thread that Inark posted the Vic forums about NSW's post count catching up to yours.
Some people take things too seriously methinks.
"And you obviously have totally no idea about SAU jet... if you did you would trash talk with George as he is not only a top bloke, but also has had alot to do with putting together the NSW club..."
i think u mean WOULDN'T trash talk with george
and...can any1 here take a joke..or trash talk and not winge about it when they get upset...i mean i know none of u so why would i ever insult u....ITS ALL FUN AND GAMES, u gotta stop gettin so offended over absolutely nothing...i cant believe how stupid all of this is...time to let it go i think..me and every1 else
LOL this has got wayyyyy out of hand....
My above posts were only meant to emphasise that this whole argument is STUPID and there is NO NEED to trash talk... as everyone here is usually always helpfull and totally friendly.... ever more importantly we are all here cos we have a common intrest...
I dont really feel the need to stoop to your level of sending an abusive PM... Oh and i dont feel the need to pull my head out of my ass either... lol wtf was that about...
guys, stuff like this just gives us reason to remove post counts completely. if that's what everyone wants then keep at it and soon there won't be any post counts visible anywhere.
i didn't come here to threaten anyone and that's not what we are about. but believe me they will be removed and then the ppl that wrecked it will blame the mods when it was YOUR fault in the first place. can't you see that?
we all want to just have fun but when it starts to get out of hand and ppl get petty they just end up wrecking it for everyone. so bite your tongues (or fingers in this case) and forget about post counts. i mean, what does it prove anyway?
hooray... thats what i was trying to say in the first place...
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
