Boxcar... thats easily fixed....
One morning i came out to my 200 in the garage to find that after i got home the previous night a cat found my bonnet so warm and cosy that it try to tear it up like carpet.... HUGE scratches all over it..
solution: a good power drill (you or a mate will have one) and a meguiars buffing pad ($20 or so from auto barn)
apply polish to the area and use the buffing attachment.
should remove it no problems. I used this on my bonnet and you couldnt see ONE scratch.....
https://www.sau.com.au/forums/topic/932-paintwork-scratches/#findComment-20485
Guest DAZSPC
Indeed the power buff does wonders if used properly, but do yourself a favour and be REALLY carefull. I don't know if buffing pads have had a big improvement recently but i recall a nasty incident involving myself, and a proper buff borrowed from a panelbeater mate and some god awful burn marks on my bonnet that required professional repair.
https://www.sau.com.au/forums/topic/932-paintwork-scratches/#findComment-20497
Guest Boxhead
well i used that top meguairs wax.. gold class today... mmhmm its damn good.. most of the scratches arent evedint... and the damn stuff smells nice too... but the ones that im worried about are still there, i actually think they have gone through the paint... so maybe im rooted.. ohwell.. ill give you suggestions a go.. thanx guys
https://www.sau.com.au/forums/topic/932-paintwork-scratches/#findComment-20504
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
