Left overs from R32 half cut. Located on southside of Brisbane.
Standard dump pipe $30
Standard front pipe $30
R32 turbo good condition but been sitting for a while (minimal end float) $250
R32 aircon condensor VGC no bent fins $80
Power steering pump and reservoir $80
R31 starter motor $50
R32 overflow bottle (no cracks) $10
R32 wiper bottle (no cracks) $10
RB20det std injectors X 6 GC $150
RB20det auto wiring loom $100
RB20det motor. Guaranteed runner, NO smoke. Has gudgeon pin knock due to shit timing tuning on microtech. Just motor and head. $200
RB20det inlet plenum $50
RB20det alternators X 2 $50 each
RB20det coil packs X 6 $100
Sorry bout the crappy pics, can take better ones if you PM me. :D
Regards
Steve
0411 206 780
Edited by RB180sx
https://www.sau.com.au/forums/topic/93241-r32-bits/
Hey, Was just wondering if you had an orange SIDE indicator cover(small round one) for an R32?
I lost one of mine somehow :S
Nath
Sorry Nath, just got the bits I mentioned. Half cut is gone! Should have pulled more off it B4 it went!! :)
Regards
Steve
https://www.sau.com.au/forums/topic/93241-r32-bits/#findComment-1682454
Do you know if the PwrSteer Pump/reservoir is HICAS version or not? Have a clearer picture or part number of it?
Where abouts on South Side are you, I am at Underwood so could drop over to check what is left as I am after a few things.
Thanks
https://www.sau.com.au/forums/topic/93241-r32-bits/#findComment-1699695
Yes it is mate. Its for an auto if that makes any difference.
Im in Hillcrest, near Browns Plains
Regards
Steve 0411 206 780
Hey mate,
Is that wiring loom, a complete engine wiring loom?
Where abouts are u located on the southside?
Cheers..
https://www.sau.com.au/forums/topic/93241-r32-bits/#findComment-1725767
    • Wife wanted basket things in the wardrobe in our temporary house. Thought about ripping our the wardrobe and fitting the entire IKEA set, but it's a temporary house and we want to move in a few years. So IKEA advertises this as a 50cm unit, however the actually basket and rails measure 46cm wide. Only issue was depth, IKEA stuff is quite deep, where as the builder special junk is super shallow at less than 40cm. Send it, chopped the rails, then offset the mounting holes, job done, happy wife, less shit scattered all over the bedroom. Did the same to the other side too. Also drove the Skyline shit box today, dropped off oil at Supercheap Auto. I didn't realise they only now take max 2x bottles per visit. I visited 2x Supercheap Autos.
    • I've seen similar actually in my situation. You never know what tables are attempted to be used when the car thinks it's -99C or +200C. The fail state is not usually that extreme but you know what I mean - it was in my case though! This is where being able to read all the sensors is useful cause you see this stuff really quickly.
    • The above is very important. However as long as you keep timing relatively low, it's plausible to make your own knock ears and plausible to learn to tune with a modern ECU that can do wideband O2 correction like a boost controller. I mean if you only have one viable road to even drive the car on, learning to tinker to this level may be worth doing given you can't do much else with the car...?
    • I find the fact that the rear plate has to be bent inwards at the rear not so bad: but the front is just awful: It's like come on. (these are my very old, now retired/turned in plates) TBH it is a lot of money to fix a minor issue, the fact I said "I'll never really spend the money on doing this" is why people ended up buying them as a gift for a 'car guy' who can be hard to shop for.. for car guy things.
    • I just bent the ends of my premo plates. It even went through Regency like that after the engine conversion and the inspector (a great bloke!) just squinted his eyes and said "I didn't see that". Plates, and how they look, are just something that have zero importance to me.
