Item: 19" Chrome Wheels
Item Condition: V Good
Reason for Selling: Upgrading
Price and Payment Conditions: $1600
Great wheels, suit the Skylines and 200's. Two new tyres 245/35 and two not new (not sure what %) 235/35
Only selling to upgrade, otherwise i'd be more than happy to keep them.
Edited by Stevie
https://www.sau.com.au/forums/topic/93606-19-wheels-tyres/
  • 1 month later...
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
