hi
ive done a search and come out empty handed....
i pick up my rb25 neo det motor today and was curious on what i should change... a air leakage test will be carried out on it and i know im already changing the oil, oil filter, timing belts, prolly any other belts on the motor (ac pump alternator ect ect) and the spark plugs...
the engine is in good nick very clean inside the rocker cover 74000 ks on the clock and has been driven by the company before they chopped it up... the turbo is a bit smoky and a good one is being arranged at no extra cost
my question... am i doing enough... is there anything else i should be changing/inspecting while its easy and out of the car... i dont want to have to rip the engine down but at the same time dont want to have the engine in and realise it has to be pulled out 3 months down the track...
the motor comes with a 1 month warranty after the computer is installed (the warranty can be stalled for up to 3 months (give me time to paint car wheels lower exhaust ect ect)) so how should i treat it??? should i give it a hard time or just let it run itsself in they are a pretty good motor from what ive read and i was lucky to get it at the price im getting the conversion at
thanks for reading my essay and thanks in advance
Rick
https://www.sau.com.au/forums/topic/93978-new-motor-now-what/
Sounds kinda like my Neo when I got it
timing belt
the rest of the belts
any suspect hoses
sparkplugs
coil packs if you want to
water pump
the thermostat on my neo was a but funny after the engine was sitting for a while, can't hurt to change that too, it's about $42 from memory
if you're keen, paint up the rocker covers while the engine is out, unless you got the engine cover with it
I'd be taking it easy for the first couple of weeks, you don't know how long that motor's been sitting there for.
sorry to run alittle off topic on this one but out of curiosity, where did you pick up the motor from. I've been searching for a good condition rb25 but havn't made up my mind yet on where to get it from... and if you don't mind me asking, what approximate price did you pay?
Edited by Archie@
hey man i got it from sss automotive in giraween they have a pretty good rep and they usually got most things...
i was lucky to get my paws on the motor, i only went down there to have a talk with them bout a gtr motor then while i was talking a bright light shined out of the container fresh from japan as the forkilft backed out with a r34 gtt front cut on its tines...
i had a look at the gtr motor and in 5 seconds changed my mind (those front diffs turned me off and hearing the stories they had) they said if i wanted something different thats the one 4 me and it fits easy...
but yer to answer your question i was in the right place at the right time i guess... i had to wait for it to get quarantined i found it so early... but yer just keep looking ive heard good things about just jap in kirawee too but havent gone 2 them yet as i live in penrith :)
maybe ask in the importers section of the forum 2 they might know a little better
good luck in your quest
    • The oil pressure sensor for logging, does it happen to be the one that was slowly breaking out of the oil block? If it is,I would be ignoring your logs. You had a leak at the sensor which would mean it can't read accurately. It's a small hole at the sensor, and you had a small hole just before it, meaning you could have lost significant pressure reading.   As for brakes, if it's just fluid getting old, you won't necessarily end up with air sitting in the line. Bleed a shit tonne of fluid through so you effectively replace it and go again. Oh and, pay close attention to the pressure gauge while on track!
    • I don't know it is due to that. It could just be due to load on track being more than a dyno. But it would be nice to rule it out. We're talking a fraction of a second of pulling ~1 degree of timing. So it's not a lot, but I'd rather it be 0... Thicker oil isn't really a "bandaid" if it's oil that is going to run at 125C, is it? It will be thicker at 100 and thus at 125, where the 40 weight may not be as thick as one may like for that use. I already have a big pump that has been ported. They (They in this instance being the guy that built my heads) port them so they flow more at lower RPM but have a bypass spring that I believe is ~70psi. I have seen 70psi of oil pressure up top in the past, before I knew I had this leak. I have a 25 row oil cooler that takes up all the space in the driver side guard. It is interesting that GM themselves recommend 0-30 oil for their Vette applications. Unless you take it to the track where the official word is to put 20-50w oil in there, then take that back out after your track day is done and return to 0-30.
    • Nice, looks great. Nice work getting the factory parts also. Never know when you'll need them.
    • Thanks @jtha7 I will have a look around tomorrow but it is a prick of a spot. These are some photos i tried taking
    • I take it that the knock retard is from bearings tapping a little tune? Thicker oil is a fragile bandaid. You need a much bigger oil cooler and probably the bigger pump being discussed.
