  • Replies 40
I bought a chip off armbrusb on this forum......
Unsoldered the origional.. got a cradle.. soldered it in... slotted new chip in..... once the computer got used to it BIG DIFFERENCE!!!!!!!!!!!!!.......
pulls higher up the rev range....
boosts sooner
better on the petrol
sounds nicer
etc etc
My estimate pushing about 20+kw with it!!
a couple of hrs work (and alot of sware words)
and a $50 chip
i heard he has more :D
best $50 ever spent!!!!!!!!!!!!
Ed
boosts sooner
sounds nicer
etc etc
and a $50 chip
i heard he has more :)
Ed
it could feel better but who knows how the car is running.
i would put it on a dyno to be 100% worth the $60 or so dollars
boosts sooner
sounds nicer
etc etc
and a $50 chip
Ed
so can u hook me up my msn is cuong_lo@hotmail.com let me know some detials i want to do it :)
got it dynod ages ago..... compared to the 118rwkw that the pervious owner had....
mine pulled 144.9rwkw.. all i had done since i got the car was service, new plugs etc etc etc.... removed a resinator (straight through mind you) and chipped it....
the a/f ratio was ALLLLLLLLLLLOT better more even etc not spiking and it boosted sooner and went on stronger :)
very happy with the result......
flukey.... pm armbrusb and see if he has anymore....
if he does ill help u stick it in :)
Ed
the a/f ratio was ALLLLLLLLLLLOT better more even etc not spiking and it boosted sooner and went on stronger :D
if he does ill help u stick it in :D
Ed
what area are u from i'm from parramatta just waiting on armbush to reply
hmm I got the chip in and went for a test run after ecu reset
problem seems to be over about 5psi and/or 3000rpm it splutters like a b*tch and wont get going couldnt really get past 3Krpm dam
pls tell me the ecu takes a while to get used to it or something mr ed32 what are your thoughts??
well shes a bit messy on boost to say the least dunno what the deal is, went for two drives and seems the same.....backfiring and spluttering basically crappy over 2500/3000rpm
maybe the ecu reset didnt work, i unplugged the battery while doing the ecu and pushed brake pedal in for a minute or so
need some ideas mr ed32!?! or armbrusb?!? u had stock turbo right mr ed32 yah?
maybe wait till mine works hey flukey.....
    • Just wanted to pop in an update on my setup. The CD swap has been great, I love the mazworks housing for the overall simplicity. I ended up sealing my trans tunnel with a thin sheet of aluminum reused some of the holes on the trans tunnel, and laid some window sealing EPS foam around the edges. Works great, really quieted things down and sealed up the car.  As for the power comment. Right now I am also running about 650whp. with the way the bell housing is attached to the face of the transmission I have zero doubts it would be fine, mainly because the input shaft and main shaft bearings are seated into the bell housing adapter. This means the load is NOT on the bolts to maintain the power, rather into he casing of the bell housing; Yes the bolts are doing some work there, but with both shafts locked in zero worries.  End of the day, the Mazworks solution is the easiest and safest. no need to take your trans to a shop to get milled perfectly, it fits with minimal clearancing, and you can use all your existing clutch and flywheel.  Driving wise the CD has been great compared to the big box, I'll probably swap my final drive at some point. The serial 9 shifter is gooooood, my only qualm is how tight it is, it takes a fair bit to get use to, 5th and 6th are a bit eh/hard to find at times, but maybe I need re-adjusting, and I think my clutch master is very tired and needs a rebuild.
    • If you are keen, have a look at my build thread. Car is for sale for the right money or straight swap for a F80 M3 LCI.
    • Welcome mate.  No point in over thinking it, buying any one of those cars you mentioned is not a smart or logical choice with the availability of many "better" (re price to performance) cars available to you.  The heart wants what the heart wants, buy whatever it leads you too.
    • Hey everyone! Im so grateful to be apart of this community and ill do my best to be apart of this. Firstly, i'm not disclosing my real name due to in real life circumstances surrounding my privacy and public image (sorry lol) Secondly, The only thing personal I am willing to share is that I'm from Sydney and a descendant of one of Sydneys largest mortgage firms. I got gifted my first ever car, a 2022 Porsche Cayenne and I love it to death. Ive been driving it for about 5 or 6 months now and honestly Im so grateful for my parents for gifting me this vehicle. However recently I've been working my ass off to afford my second car (which I need help deciding soooooo community help me out please?). Once decided, im planning to try modify it myself. Recent I've been thinking about getting a Skyline, particularly a 25GT or GT-V, yes I know overrated as hell, but I'm also considering a Chaser which I recently came to love. However my dream is to one day own a 180SX (So hard to find clean versions and im not really into importing).  Lastly before I send this off, I want to apologize if I sound tacky or pretentious. I try not to and want to genuinely learn from everyone and anyone. (Im no expert in this area) Thanks for reading!
    • I've got three stashed away but it's starting to get silly with the prices
