I have sold my standard GTR fuel pump from my R32 GTR and bought a factory R32 GTSt fuel pump, and an aeromotive A1000 external pump ( this one ). I need to shift my car to the other side of town, but i cant get a surge tank for 2-3 weeks. Will my car run on just the GTSt fuel pump? Or will it run with low fuel pressure and cause my car to run lean? And an external fuel pump must have a surge tank/swirl pot, correct?
Thanks guys!!
Adam.
https://www.sau.com.au/forums/topic/94510-gtst-fuel-pump-in-gtr/
I do believe it will run fine, provided you arent maxing out the gts-t pump. If you could keep it off boost ~4-5% injector duty cycle, then i dont think you would have any problems
Ah thats awesome, thats what i thought too, just needed another opinion! thanks!
Unless you plan to do a lot of circuit work / drag racing I see no need for a surge tank.
You can even get away without having one as long as you keep your fuel tank full.
I doubt you'll have any fuelling problems - it anything it will probably run rich - I know of guys that run a standard r31 non turbo pump in tank and use a bosch external in high hosepower applications. Your external will give you plenty of fuel pressure.
These are the specs of your pump below, now why are you buying one of these at $290 US when you can buy a bosh or walbro pump that will give you close to the same sort of power I think the walbro in tank supports up to around 450kw (could be wrong on that figure) sorry to be so negative but it just seems like there is a lot of better options locally and for less money.
Specs:-
For carbureted powerplants making up to 1200 HP and fuel injected engines:
up to 700 HP - forced air induction
up to 1000 HP - naturally aspirated
up to 1200 HP - carbureted systems at the track, on the street, and in the water.
  • 3 weeks later...
Yea ill probably just put it in line without a fuel cell for the mean time.
havent got a fuel cell yet matt, where should i get one from? maybe we should get someone to make up 2 for us (1 each!) :)
Yea if i were buying a fuel pump id buy a walbro or bosch, but i got this real cheap, so im going tyo use it.
    • Cheers. Skyline is back on the menu, can’t get rid of it. It’s like a child you don’t want, or herpes
    • I got back to Japan in January and was keen to get back on track as quickly as possible. Europe is god-awful for track accessibility (by comparison), so I picked up a first-gen GT86 in December just to have something I could jump into right away. The Skyline came over in a container this time and landed in early January. It was a bit battered after Europe, though—I refused to do anything beyond essential upkeep while it was over there. The clutch master cylinder gave out, and so did the power steering. I didn’t even bother changing the oil; it was the same stuff that went in just before I left Japan the first time. Naughty. Power steering parts would’ve cost double with shipping and taxes, so knowing I’d be heading back to Japan, I just postponed it and powered through the arm workout. It took a solid three months to get the car back on the road. Registration was a nightmare this time around. There were a bunch of BS fees to navigate, and sourcing parts was a headache. I needed stock seats for shaken, mistakenly blew 34k JPY on some ENR34 seats—which, of course, didn’t fit—then ended up having the car’s technical sheet amended to register it as a two-seater with the Brides. Then there’s the GT86. Amazing car. Does everything I want it to do. Parts are cheap, easy to find, and I don’t care what anyone says—it’s super rewarding to drive. I’ve done a few basic mods: diff ratio, coilovers, discs, pads, seat, etc. It already had a new exhaust manifold and the 180kph limiter removed, so I assume it’s running some kind of map. I’ve just been thrashing it at the track non-stop—mostly Fuji Speedway now, since I need something with higher speed after all that autobahn time. The wheels on the R34 always pissed me off—too big, and it was a nightmare getting tires to fit properly under the arches. So I threw in the towel and bought something that fits better. Looks way cleaner too (at least to me)—less hotboy, less attention-seeking. Still an R34, though. Now for future plans. There are a few things still outstanding with the car. First up, the rear subframe needs an overhaul—that’s priority one. Next, I need to figure out an engine rebuild plan. No timeline yet, but I want to keep it economical—not cutting corners, just not throwing tens of thousands at a mechanic I can barely communicate with. And finally, paint. Plus a bit of tidying up here and there.
