I have sold my standard GTR fuel pump from my R32 GTR and bought a factory R32 GTSt fuel pump, and an aeromotive A1000 external pump ( this one ). I need to shift my car to the other side of town, but i cant get a surge tank for 2-3 weeks. Will my car run on just the GTSt fuel pump? Or will it run with low fuel pressure and cause my car to run lean? And an external fuel pump must have a surge tank/swirl pot, correct?
Thanks guys!!
Adam.
https://www.sau.com.au/forums/topic/94510-gtst-fuel-pump-in-gtr/
I do believe it will run fine, provided you arent maxing out the gts-t pump. If you could keep it off boost ~4-5% injector duty cycle, then i dont think you would have any problems
Ah thats awesome, thats what i thought too, just needed another opinion! thanks!
Unless you plan to do a lot of circuit work / drag racing I see no need for a surge tank.
You can even get away without having one as long as you keep your fuel tank full.
I doubt you'll have any fuelling problems - it anything it will probably run rich - I know of guys that run a standard r31 non turbo pump in tank and use a bosch external in high hosepower applications. Your external will give you plenty of fuel pressure.
These are the specs of your pump below, now why are you buying one of these at $290 US when you can buy a bosh or walbro pump that will give you close to the same sort of power I think the walbro in tank supports up to around 450kw (could be wrong on that figure) sorry to be so negative but it just seems like there is a lot of better options locally and for less money.
Specs:-
For carbureted powerplants making up to 1200 HP and fuel injected engines:
up to 700 HP - forced air induction
up to 1000 HP - naturally aspirated
up to 1200 HP - carbureted systems at the track, on the street, and in the water.
  • 3 weeks later...
Yea ill probably just put it in line without a fuel cell for the mean time.
havent got a fuel cell yet matt, where should i get one from? maybe we should get someone to make up 2 for us (1 each!) :)
Yea if i were buying a fuel pump id buy a walbro or bosch, but i got this real cheap, so im going tyo use it.
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
